Question about Tappan TGF303BW Gas Range
Unable to ignate the oven pilot light - Tappan TGF303BW Gas Range
  • Tappan Master
  • 8,220 Answers
Posted on Jul 01, 2009
Put in new ignator will not lite
Did you follow installation instructions on the ignitor? The pilot light may have gone out. Try turning the gas off to the dryer for a couple minutes and then following the pilot light lighting instructions for the valve assembly. Youtube has many good videos on this as well.
Dec 01, 2014 | Maytag Dryers
I have 36 in Imperial SS gas stove with constant pilot lights on .i believe its a commercial unit.I am unable to start pilot light for oven ,rather it starts and as soon as i release red button ,flame goes...
it sounds like the thermocouple which is heated by the flame is faulty its purpose is to hold the gas valve open so gas can flow but if the pilot goes out the thermocouple stops producing electricity and so the valve closes its there for safety reasons
Oct 13, 2014 | Kitchen Ranges
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
GENE
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Unable to find pilot light for m,ajic chef oven
its electronic ignighters is it plugged in and have you tried turning it to light new ones dont have piolets
Jul 13, 2008 | Magic Chef Ovens
Vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Nov 16, 2007 | Ovens
Tappan TGF303BW Gas Range Logo
207 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
