Question about Goodman CLQ36AR49 Air Conditioner
Model gsc13042aa goodman central air unit sevice manual
  • 51 Answers
Go to goodman web site
Posted on Aug 09, 2009
    Problem Solver:
  • 18 Answers
Just go onto goodman website and download pdf file if that doesnot work call godman with model #
Posted on Jul 18, 2009
My dog ate wire on central air unit it’s a Goodman ck241B does anyone know what this wire is and can I splice back together to get air again it has red blue green and white wires in side a white wire but...
Page 7 in this Goodman installation manual shows those colours on a 3 phase installation.
https://www.alpinehomeair.com/related/Goodman_Condensing_Unit_Install_Instructions.pdf
After you work it out, cover the wire with pvc water pipe or even old garden hose. Put Tabasco sauce on the outside.
Jun 25, 2018 | Goodman Heating & Cooling
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Central air only blows a small amount of cool air out the vents. After running 12 hours it only cooled my small 1BR apartment 3 degrees. The filter has not been replaced since October 2009 but I can't seem...
I have a Goodman A/C unit APRF036-00B1. The out side unit seems to be sucking and bowing air, the coil is cool to the the touch and the blower seems to be turning. I've check what seems to be the obvious. A small amount of air is only coming out. Any suggestions?
Feb 21, 2011 | Goodman CKL36AR36 Air Conditioner
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
How many tons is a Goodman Central Air Unit with Model Number CKL30-IE?
That is a 2.5 ton system. The model numbers are as indicated:
24- 2 ton.
30- 2.5 ton.
36- 3 ton.
42- 3.5 ton.
48- 4 ton.
60- 5 ton.
Hope this answers your question!
Jul 15, 2010 | Goodman CKL60AR60 Air Conditioner
Central air not working
the pilot light has nothing to do with the operation of the central 'air' system.
As to the central 'heat' system however, it must be lit.
hope this helps.
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Can i get an owners manual to my ambient heatpump model hypfcr
the home owner don't need a user manual for a central a/c unit because there is nothing you need operate. the only interaction you have is on the thermostat but thermostats are sold separate from the a/c unit and comes on different brands and configurations see what brand and model is your thermostat and then you can find the user manual for it. If can't find it just get a new thermostat you can get then even at Walmart and range from $40 to $60 they come whit user manual.
Jun 11, 2009 | Goodman GPC1342H21A Air Conditioner
My goodman cple18-1c model central AC unit blowing hot air
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Sep 13, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
316 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
