Question about Roper FGP305 Gas Kitchen Range
Oven Doesn't Even turn on
I have a Roper by Wgirlpool about 2 years old and it may take 4 hours before it will turn on once I set it for 350 degrees. It actually doesn't matter what temperature I choose. Sometimes it will come on and sometimes it won't. I never know if I will be able to cook that night until I turn the oven on. it sometimes warms up to about 200 and stays that way, never heating to a cooking temperature. Any ideas?
    President:
  • 1,723 Answers
The oven thermostat controls the oven temp. It is not working and you need a new one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 | Cooking
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
Oven temp is inconsistent. Sometimes it works but most of the time it doesn't. Yesterday we set it at 350 degrees. Two hours later it only came up to 250 degrees. I've replaced the oven sensor but...
Is this a gas oven? gas ovens rely on ignitor/glowbar ignition. The system uses amp draw to open the gas valve. If the ignitor is off a tad in amp draw then kickin or bangin on the stove sometimes makes that puppy work.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 20, 2011 | Kitchen Ranges
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Roper FGP305 Gas Kitchen Range Logo
403 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Craig Butler
Craig Butler
Jim Thurston
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
