Question about Whirlpool LSR5132PQ Top Load Washer
Washer won't agitate, already put a new timer on. After it was installed I went through all the phases and it worked, then when I put clothes in it would not agitate.
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. Take note of your symptoms: 1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch. 2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling. If you still have questions, please let me know. I hope this information is helpful to you.
Posted on Jul 01, 2009
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
My kitchenAid clothes washer won't always agitate but the timer will finish the cycle
Possible that the timer is not switching the circuit to the designed cycles and so it does not go to the spin mode. It can be due to loss in mechanical contact due to worn out points or dirt accumulation. Use a cleaner, WD40 , could be good to try on the timer before you can estimate the cost of a timer.
Jan 20, 2013 | Washing Machines
WASHER FILLS WITH WATER AND AGITATES FOREVER. I
Based on your discription you do need a new timer.
Jun 11, 2010 | Hardware & Accessories
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Spins while agitating...only after new motor and timer
not that unique, whats happening is the transmission has a wig wag and shift cam bars that are not moving at the right time. you probably have an open coil on the wig wag and its normal for them to do this when a coil fails. just take the 5/16 screw out of the wig wag and lift it off the plungers, then replace it with a new one. all should work correctly after that.
Jan 05, 2009 | Whirlpool GSC9455 Top Load Washer
Basket spins while agitating
transmission defective...not a special problem,,,the transmission shot...
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Final agitation and spin do not happen, timer does not stop
check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Nov 20, 2006 | GE WBSE2090A Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
125 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
