Question about Asrock P4I45GV R5 Motherboard
ASrock Prescott 533 (P4i45GL) not recognizing AGP bus
I just got an ASrock Prescott 533 (P4i45GL) motherboard. However, I am only able to use the integrated graphics processor.
It appears the AGP bus is not even recognized by the BIOS. I have upgraded the Chipset drivers twice already and no go.
Is anybody aware how to solve this problem?
I ve P4i45GL Motherboard I want to boot from USB, I made PenDrive bootable XP, i set first bootable device USB..and restart it detect searching for boot record from USB RMD-FDD..OK ..!! and then system stuck(in case i format pendrive with FAT32)/restart(in case i format pendrive with FAT32).
Posted on Mar 15, 2010
  • nightwalk121 Dec 03, 2010
    I am sorry but you're ALL wrong. The P4i45GL/GV series are incompatible with a whole bunch of cards, and when it finds one it can't run, it defaults to the onboard video as if the agp slot doesn't exist. There's a list on the asrock website that lists most of the compatible cards.
  • 375 Answers
The AGP bus is certainly meant to be accessed - if you can't it is either of a few things - faulty card or faulty motherboard, incompatible card.
Posted on Jul 01, 2009
  • Asrock Master
  • 4,806 Answers
Well, the board supports AGP 8x cards so you should have no problem there.
Go into the BIOS utility and tell the BIOS you want to use the AGP as the main controller, it will be in a sections of the bios so you will have to look for it.
If you cant find it, pull the power cord from the back of the machine, remove the side panel, install the card (if it's not already in) and take out the motherboard battery for 10-20 minutes periodically hitting the on/off button, this will clear the bios settings.
After the time is up put the battery back in, and power cord and boot the machine up.
It should now be fine!!
Oh, the AGP card cannot be seen in the bios, it does however appear very fast when you first turn on the machine providing the splash screen is disabled.
Good luck.
Asrock motherboard model P4i45GV rev. 5.01 debug error code "AD" whats the problem
hi this is Mohan.s i wont
asrock p4i45gv prescott 533 motherboard
on internet so plz
Feb 26, 2011 | Asrock P4I45GV...
How to download asrock prescott 533 p4i45gv USB 2.0
HI,
PLEASE GO THROUGH THE LINK
http://downloadnew.org/drivers/other-drivers-tools/asrock-p4i45gv-r50-intel-usb-20-driver-391983.html
HERE YOU CAN DOWLOAD YOUR asrock prescott 533 p4i45gv USB 2.0 DRIVER.
GOODLUCK
Jan 21, 2011 | Computers & Internet
I need motherboard driverfor prescott 533 asrock p4i45gv.............. please help..............
got to asrock site here
http://www.asrock.com/mb/overview.asp?Model=P4i45GV R3.0
if this not right one then type into search p4i45gv and choose the right one, then you have access to everything you need.
Aug 13, 2010 | Asrock P4I45GV...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
VGA AGP card is Support / Not?
that the card is compatable with your version of windows is more important.
Mar 11, 2009 | Asrock P4I45GV R5 Motherboard
Gigabyte GA8ST800 Motherboard
The Gigabyte website has drivers for the onboard soundcard available, but according to the specs for the Gigabyte GA8ST800 Motherboard there is not built in video card on that model so I'm guessing that is not what you have. See the links below as both have specifications and pictures of their boards that should help clear up which board you have. .
The ASROCK P4i45GL does have the Integrated Intel Extreme Graphics adapter built in, do if that is the MB you have, you should be able to use the drivers linked below.
Drivers/Documentation for the Gigabyte GA8ST800
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1681
Drivers/Documentation for ASROCK P4i45GL
http://www.asrock.com/mb/download.asp?Model=P4i45GL%20R3.0&s=478
Cheers
May 29, 2008 | Computers & Internet
Driver for prescott 533
go the manufacture website and download it for free
May 12, 2008 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Asrock P4I45GV R5 Motherboard Logo
1,010 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
