We've had it for a long time and this just started about 10 days ago.
SOURCE: Our blast freezer continues to frost up inside
Defrost termination is not working it should be terminating on temp. its terminating on time if it is a small blast freezer their is a high limit switch not opening. if you can adjust the time average defrost time 25-40 minutes try decreasing by 5 minutes no less than 20 minutes you will need to make sure that the coil clears after defrost.
SOURCE: Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
SOURCE: Frost and icicles building up after defrosting
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
