Question about Boating
Directional cable snaped from foot pedal to head
There are two directional cables which go from the foot pedal to the head of the motor.
One snapped so its apart in the driveway.
On each end of the cable there is a small square metal stopper which holds the cable into place either on the foot edal or on the head.
My question is with those ends being bigger because of the stoper, how do i feed the cable through from the head to the pedal?
Minn kota 101lb maxxum
    Scholar:
  • 155 Answers
Not sure if this is what your doing, but I would get BOTH cables and replace them, they should unhook and removed from both ends, if the ends are "flared/exspanded" and unable to exit thru the mounting hole, cut the end off and remove .... its easy to change, unless you have other issues with yours....hope this helps..gl
Posted on Jul 08, 2009
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
Jan 25, 2016 | Cars & Trucks
I have acquired a necchi automatic supernova. I want to know how to install a foot pedal - it never came with one. It did come with a sewing motor controller (dark brown/black block with two cables leading...
foot pedal is a HD voltage regulator that controls the motor speed by simply increasing/decreasing voltage supply. e.g. if the two wires to the foot pedal were connected the motor would get full voltage and run at max speed. most foot pedals can be adapted for your machine
Feb 16, 2014 | Sewing Machines
2000 ml320 parking brake pedal will not release, hand release has no tension, alarm sounds continuously, but seems to drive fine
sound like the cable has snaped on some part of the system get the cable snaped the alarm will go off when the foot pedal is in the off position
Jan 21, 2014 | Mercedes-Benz Cars & Trucks
I have a peugeot boxer 1.9d van and cant remove the clutch cable from out of bulk head, pedal side as it has snapped, do you have any ideas
If the cable has completely snapped and not attached to the clutch pedal, the whole cable, casing and broken cable should just about fall out of the bulkhead. I have never had a problem with that on any vehicle.
Apr 18, 2011 | Peugeot Liberte Cars & Trucks
My foot controlled trolling motor pedal is slipping when turning
Your cable may have broken or slipped and maybe bending rather than shifting in the sleeve. You may also want to check and make sure all set screws and cable locks are secure.
May 16, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a BJC80 printern with a scanner head. My pc is an xp opertins system. It is connect to parallel port but when i try to scan, it sends me back an error message saying there is no communication.
One of two issues may be involved. 1) Make sure you have a bi-directional IEEE-1284 parallel printer cable, 6 feet or less long. 2) Make sure that the parallel port is set to ECP mode (the BIOS is accessed by hitting F1 or F2 during boot on many computer, check your manual.) Try a new cable (just in case the cable has just enough damage to prevent the scanner from getting the full bi-directional communication).
I hope this helps.
(the lack of bi-directional communication only disables the scanner, the printer will still work)
May 08, 2010 | Canon BJC 80 InkJet Printer
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Ryobi trimmer not spinning, the motor runs fine, I think the friction clutch is worn.
Either the cintrifugal clutch is not engaging(if that model has one). Or the drive cable is snaped, or the rotary head drive lug is stripped. Pull off the drive head(where the nylon cord goes) & behind it is a flexable cable that transmits drive from the motor to the drive head(bobbin).pull it out and see if its broken.Check The rotary drive head lug,its on the top of the drive head (bobbin) you removed.
hope this helps
Regards Andrew Porrelli
Dec 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need adapter for old 12-pin foot pedal to USB
tiger direct.com has adapter cables for several devices
tigerdirect.com cables unlimited.
Sep 12, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
107 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
