Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Can the fresh food drawers be disassembled? - GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
  • 40 Answers
Yes they can be disassembled but it should not be special temperature drawer or zone which can be independetly controled otherwise you can change the temperature deviation in the compartment which can lead colder temp or below freezing .not good for the fresh food.
Posted on Jul 01, 2009
I have a Kenmore Fridge Model 596-729-12200
fb4dfaa6-7995-4ceb-a384-cb74f4ab1f6a.jpgThe fresh food section has a 67003410 Damper that has a thermostat probe that senses the fresh food section temperatures and then regulates the fresh food section cold air from freezer by opening and closing to maintain a set temperature. If defective the damper may remain closed or remain closed. You can test the damper by removing and placing the temperature probe into a glass filled with ice and no water. The damper should close in the ice and open when not in the ice. I will be here to answer any questions you have, Thanks Sea Breeze
May 02, 2013 | Refrigerators
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
How to stop water from pooling on the middle of shelves. The water seems to come from nowhere. Also, what is the best setting for the humidity sliders on the fruit and vegetable drawers.
If it is a static appliance with a ventilator this can happen at colder settings you can try to increase the setting so the condensation can be decreased.That water is the condesed water which comes from your food.
Actually these has a very small impact if you do not have %100 sealed drawer.If you have fresh vegies it should be totatlly closed so the humidty levels increase in the drawer so the freshness.
Sep 26, 2009 | Maytag Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
