Question about Refrigerators
My refrige does not dispese water - Refrigerators
  • 4,070 Answers
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
Posted on Jul 01, 2009
The ice maker is making ice but when we push the dispeser from the outside it only shoots out water and no ice. What is the problem?
your dispenser will only do one or the other??... I my be wrong, but I have never seen one dispense water and ice at the same time???
Jul 11, 2017 | Refrigerators
Water leeks from dispeser on a Westinghouse
check bottom back see if water solenoid or line leaking
Feb 16, 2014 | Dometic RM2452 Refrigerator
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
The water dispenser and ice maker have stopped working
I would recommend to check the water shut off valves at the wall (behind the refrigerator) and under the sink before you call a plumber.
Aug 11, 2009 | Refrigerators
Water in door not in washer
there is a dispeser tube at about eleven oclock in the door boot make sure it is in the rubber boot
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
thanks
joyce
Feb 06, 2009 | Kenmore Elite 45986 Front Load Washer
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hight water level on rinse stage
hi there sounds like you may have a faulty pressure switch, this is located at the rear of the soap dispeser box under the lid.
May 25, 2008 | Hotpoint WF430 Front Load Washer
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
