Question about Kenmore Dryers
I want to open the lower face panel on the front of the dryer
  • 370 Answers
There is two pins you have to depress with a screw driver. Look the crack in the panels and you will see. They are about 1 - 2 inches from the side.
Posted on Jul 01, 2009
How do you replace belt on dryer
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 03, 2011 | Kenmore 62602 Electric Dryer
Replace dryer belt
Installing the belt
facing down.
Please RATE me
Dec 31, 2010 | Whirlpool LER4634J Electric Dryer
How to open the dryer to get at the belt
Installing the belt
facing down.
Please RATE me
Dec 29, 2010 | Dryers
HOw do I change the belt on the Kenmore model 96281800 dryer
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Kenmore 63942 Dryer
Dryer stopped spinning. Opened top and found thin broken belt. How do you reattach new belt to drum and pulley?
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Maytag PYE2300AY Electric Dryer
Are there 4 support rollers? Instructions on how to replace them. Thanks - Doug
Now you can replace your drum rollers at this time
Installing the belt
facing down.
Please RATE me
Dec 22, 2010 | Kenmore 800 7983 Dryer
How do I replace the dryer belt?
sorry see the make, here is how u do the job
Instructions Things You'll Need:
  • Screwdriver with interchangeable bits
  • Putty knife
  • New dryer belt for GE Hotpoint electric dryer
  1. Step 1 Unplug the dryer and pull it out from the wall. Take out the upside-down screws in front that hold down the top. In older Hotpoint models, they will be under the rim of the top in front. In newer models, they will be on the inside of the dryer door opening, facing up. Slide your putty knife under the top rim to pry it up and get your fingers under it. Lift the top off the machine and set it aside.
  2. Step 2 Take out the screws that hold the front of the dryer in place, which will be on the upper inside of the box, on either side, facing toward the front. Pull the dryer front off. Keep the side with the wire connections next to the dryer (so you don't have to disconnect the wires) while opening the other side away from it like a door. The wiring side will vary.
  3. Step 3 Slip the belt off the dryer drum from the front. It won't come out completely; it will be held in one lower corner by the motor assembly.
  4. Step 4 Remove the access panel on the lower part of the back of the dryer by removing the screws. Access the motor unit. Note the configuration of the belt in the pulleys, then slip the belt off the pulleys by pushing the larger pulley forward.
  5. Step 5 Slip the new belt onto the drum from the front, with the ribbed side against the drum. Re-string it on the pulleys from the back, in the same configuration as the old one. Manually turn the drum several revolutions to make sure the belt is straight.
  6. Step 6 Put the rear access panel back on with the screws you took out. Close and re-secure the front and top (in that order) as they were before. Plug in the dryer.
Jul 07, 2010 | Hotpoint Dryers
What's the easiest way to open up a dlb6850 dryer to check the belt?
Unplug the dryer.
The easiest way to check the belt is remove the plate on the lower rear of the dryer. Look in to see if the belt is attached around the pulley wheel.
The only way to change the belt is to remove the screws in the front panel. Open the door. Look up in the door opening and remove these screws. Then you can raise the lid.
If the belt needs changing you must remove the 2 screws in the top right and left sides of the front panel.Just inside the front panel.Then disconnect the door switch wires and remove the front panel.
Slip the belt over the drum. Then open the lower rear panel to reach in to put the belt around the tension pulley.
Nov 12, 2009 | Hotpoint Dryers
I wanr to change the drum belt - hotpoint dlb1550pllwh
hi, do this Step 1 Unplug the dryer and pull it out from the wall. Take out the upside-down screws in front that hold down the top. In older Hotpoint models, they will be under the rim of the top in front. In newer models, they will be on the inside of the dryer door opening, facing up. Slide your putty knife under the top rim to pry it up and get your fingers under it. Lift the top off the machine and set it aside.
  • Step 2 Take out the screws that hold the front of the dryer in place, which will be on the upper inside of the box, on either side, facing toward the front. Pull the dryer front off. Keep the side with the wire connections next to the dryer (so you don't have to disconnect the wires) while opening the other side away from it like a door. The wiring side will vary.
  • Step 3 Slip the belt off the dryer drum from the front. It won't come out completely; it will be held in one lower corner by the motor assembly.
  • Step 4 Remove the access panel on the lower part of the back of the dryer by removing the screws. Access the motor unit. Note the configuration of the belt in the pulleys, then slip the belt off the pulleys by pushing the larger pulley forward.
  • Step 5 Slip the new belt onto the drum from the front, with the ribbed side against the drum. Re-string it on the pulleys from the back, in the same configuration as the old one. Manually turn the drum several revolutions to make sure the belt is straight.
  • Step 6 Put the rear access panel back on with the screws you took out. Close and re-secure the front and top (in that order) as they were before. Plug in the dryer.
  • thank you
    vijay
    (vote for me)
    Sep 23, 2009 | Hotpoint Dryers
    Replace heater element
    Unplug the dryer.
    Open the lower front panel.Use a putty knife to push in thclips on top of the lower front panel. They are about 2 inches in from each side.
    Lower the panel. The heater will be in front of you on the bottom right.
    Are you sure the heater is bad?
    It may be another part.
    Apr 12, 2009 | Kenmore 63032 Electric Dryer
    Dryers Logo
    48 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
