Question about Mitsubishi CS-40503 TV
40" cs-40503 Popping noise
Have a popping noise intermittantly doesnt seem to effect picture? sound seems to be coming from around top of picture tube? Thinking of buying this but dont want a can of worms? Any suggestions,Is this a good set,Do they seem to last and do you have an Idea how old it may be.Date seemed to be rubbed off of tv Thanks Darren
  • 324 Answers
Sounds like there is a lot of dust on the crt, itself. This will cause a high voltage "snap" which I think you are hearing. This sometimes happens when there has been a spill of water or other liquid that has run or dripped down on the crt. Usually is not a problem if you turn the power off, unplug the cord from the wall outlet, take off the cover, let it set for a while( just to make sure the Hi voltage has drained off), disconnect and ground the hi voltage lead to assure drain down, then clean the dust off of the crt. Follow the dust off with a damp rag and wipe off all of the remaining dust that you can. Let things dry for a half hour or so. Reassemble and see how it works. I have had several $10 tv's that this process has worked well on. Each one lasted several years at least.
Posted on Nov 09, 2007
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
Dec 10, 2009 | Mitsubishi CS-40503 TV
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
02 silverado gas tank popping noise after startup & shutdown
It could just be the heat shield around your exhaust expanding and contracting again when your engine cools down. Sounds like a tin can type of popping noise?? If it is that's the heat sheild from the engine that protect's the spark plug wire and around under the truck cabin. Good luck and hope you find where the noise is coming from.
Apr 06, 2009 | 1999 Chevrolet K1500
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
