Home | Agfa | SnapScan 1212p Flatbed Scanner | Need a driver for a SNA...
Agfa SnapScan 1212p Flatbed Scanner
Problem for Agfa SnapScan 1212p Flatbed Scanner
Need a driver for a SNAPSCAN 1212 (AGFA)
By hauschkalady on Jul 01, 2009
Hi
I have the scanner but lost the driver 2 computers ago. Any help would be appreciated. thanks in advance
Best Solution
posted on Jul 01, 2009
Very Helpful)
aysaam
Rank: Wiz
Rating: 81%, 245 votes
Hi Friend,
You are in need of Drivers for your Snapscan 1212(AGFA),u can down load it for free from the below link,
U have not mentioned which OS are u using but i will provide the link from that u may select the particular OS and download the file which one is needed.And u can also download the user guide for this model
The link is as follows,
http://static.agfa.com/digicam_scanner_drivers/scanner/snapscan_1212u/index.html
Check and kindly rate this,
Thank for using Fixya
Regards,
Ayyasam
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
rebelbw
Rank: Wiz
Rating: 80%, 54 votes
Copied from an old blog on this same issue circa 2004: I hope this helps.
You may be out of luck. Agfa stopped its desktop scanner and digital camera business in September of 2001, which is the most likely reason why you aren't getting an answer to your e-mail. However, this site may have a workable beta driver:
<A HREF="http://www.windowsxp-drivers.com/drivers/50/50310.htm" target="_new">WindowsXP-Drivers.com</A>
The password and user name for DriverGuide.com is:
User: drivers
Pass: all
As for the software, you may be forced to try something else in combination with the scanner. Agfa has made it clear that the latest versions of the software (FotoLook 3.6) does not support parallel port scanners. And neither will ScanWise 2.0 and the included driver.
Take note that some users found problems using the scanner unless the parallel port was set to standard in the BIOS, instead of ECP, when running Win2K. The same thing may apply to WinXP.
Personally, if I was in your shoes, and couldn't afford a new scanner ... <i>and</i> managed to get the scanner recognized in WinXP, I'd be looking for better software for scanning; something like <A HREF="http://www.hamrick.com/" target="_new">VueScan</A> or <A HREF="http://www.silverfast.com/highlights/en.html" target="_new">Silverfast</A>, if you can't manage to appropriate a recent copy of Photoshop, or other graphics software near that caliber.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Agfa SnapScan 1212p Flatbed
Questions and Unsolved Problems for Agfa SnapScan 1212p Flatbed
Do you recommend Agfa SnapScan 1212p Flatbed Scanner?
Answer
Answer
it powers on, adjust s positions and then turns off
Answer
snapscan 1212u It is completely installed and a notice says it is "ready to go" , when I... (More)
Answer
my snap scan 1212 flatbed power will not stay on. I use it a lot over the last two weeks. Now today... (More)
Answer
Is it possible to get this problem solved for free?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Agfa SnapScan 1212p Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
