Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
TV volume goes down with out being touched
Volume goes up with remote, but lasts a few seconds and goes back down to zero.
    New Friend:
I just recently encountered the same problem with a Sony Bravia KDL-46EX500. It started out of nowhere but after what seemed to be an update from the cable company. The volume would go down to zero and the LCD light on the front of the TV would continually blink. After trying many "solutions" including resetting the TV to factory defaults, , I removed the batteries from the cable universal remote (Comcast Xfinity) and used only the TV remote and the TV worked fine. When I reinstalled the batteries into the Xfinity remote, the problem started again. So I tried using some of the other codes listed for Sony televisions and found that an alternative code (10273) would also control the TV but not reduce the volume automatically. So, in short, try looking for a different, usable code for any universal remote that you may be using - it may be the problem.
Posted on Apr 17, 2014
  • 335 Answers
May have a sticky button or a shorted transistor switch.
Posted on Jul 01, 2009
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Sep 24, 2009 | Televison & Video
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
724 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
