Question about GE WDSR2080D Top Load Washer
GE WHDSR31 clothes basket not centered, off to one side
My wife went out of town for a few days and upon return she started to wash her clothers in our GE WHDSR31 washer. Our daughter had used the machine shile my wife was out, and now the basket is off to one side, not centered. If you move it to center, it goes back to the one side. We haven't turned the machine on as yet, kind of afraid to, don't know what happend to result in this...do you have any suggestions for fix? Thank you in advance for any help you can give us!
  • opalmertre Jul 02, 2009
    It looks like all four struts are in place. Do you know if there is supposed to be a rod through the two brackets on the sides of the motor pointing down and the two larger brackets on the base of the machine pointing up to stabalize the motor while it is running? There is no evidence of any support here at all. When running the entire lower assembly looks like it could move if it had a load that was off balanced. A small broken piece of the top of the tub was on the floor of the machine, bout 2 inches long and 1 inch wide at largest area. It looks like there should be a bolt or rod through the brackets that I decribed above on the base of the motor and base of the machine. Do you know if that is possibly the problem and it never was installed?
    Thank you for your continued efforts to help me.
  • 1,543 Answers
Use a putty knife to push in the clips holding the washers front panel on. They are a couple inches in from each side at the seam where the front panel meets the washer's top. With the front panel off, check the four suspension rods to see if one has come out of it's holder on the bottom area of the tub.
Posted on Jul 01, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jul 07, 2009
    Sorry I forgot to check for comments. The missing rod you speak of was where the shipping rod was, and should only be inserted when the machine is being moved to a new location. If all support rods are in place, also check the top frame of the washer where the supports hang from. I have seen the area cracked / bent so that a support rod (and thus one corner of the machine) hangs down, and allows the washer to bang into other parts of the machine it would normally clear.
What is error code E57?
E57 Checksum failure Software error occurs - checksum failure. Non-recoverable error. Main control board must be replaced.
Nov 07, 2014 | Washing Machines
Rover 75 forum
the car as a wire connected to the chassis and he is descharging the battery. you have to go to a car electrician and look wall the cables to see where he is not isolated.
Mar 11, 2014 | Cars & Trucks
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
My washer intermittenly doesnt spin - not all water is pumped out
there is no belt, if the coupling was bad then it would not spin at all. Sounds like it could be a worn basket drive.
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
"OL" error message
I believe that I had this same problem. The machine was skipping the wash cycle. After the water level rose to where you would expect the machine to go into an agitation cycle to wash clothes; it would start a spin cycle and drain the water. In the process of spinning it would stop to display the OL message over and over again as quick as you redistribute the load.
I found the problem to be clothes that got stuck underneath the impeller (round thing at the bottom center of the basket). Somehow I also had clothes get pulled down and got stuck underneath the basket next to the lint filter, these items were shredded to the point that they probably were not causing any issues, none the less they should not have been in there. Even though it was not the problem, I went ahead and took out and cleaned the lint filter since it was within reach.
This machine works a bit different then other machines. The agitation cycle is dependent upon the basket floating up and disengaging from the drive shaft. I guess the clothes that got stuck beneath the impeller did not allow the basket to float high enough to disengage from the drive shaft. Because the basket was still engaged to the drive shaft the drive motor would spin the basket and start a drain cycle rather agitate the load to wash it. The imbalance of the basket caused by the clothes stuck underneath the impeller kicked of the OL error since the basket was spinning at an unacceptable angle. I am not a repair dude but based on my observation of what I did to fix the problem this explanation works for me.
I've attached some pages of a repair manual that I found on-line to illustrate the areas that I am referring to.
Mar 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
GE WDSR2080D Top Load Washer Logo
132 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
