Tu unlock the keypad lock, you should have a remote control.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
SOURCE: No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
SOURCE: Problem with HP-T4254 Samsung television model
I think you have to have something plugged into video inputs or RF INPUT for sound to work. Otherwise you get a blue screen and it says no input. or not available. Does this set have an off air HDTV tuner? IF it does, try hooking it up and see if you get sound then. Good luck and that should solve you problem. If not, reply back and we will continue with troubleshooting. Thank You Jay
SOURCE: When you hit the power button, the light turn blue
check 2 1000MF 16V Capacitors on power supply.
SOURCE: I accidently hit the FPA
I REALLY doubt,if universal lock could work on your model. On most of the RCA models i came across, ORIGINAL REMOTE is required.There is only 1% possibility that universal remote could work. First of all, try to disconnect the TV for few minutes, say 15 minutes and then turn it ON.
FPA is front panel access; the front panel
controls are locked. Depending on the model number, something like
32F420T. FPA may be unlocked using the original remote, press the MENU
button and disable FPA in one of the sub-menu settings. Again depending
on the model, some require pressing & holding on the MENU at the
remote while pressing on any one button of the front panel.
If you have a universal remote, use the remote "Main Menu/Preference and set FPA lock to OFF".If you are unable to access menu, you need to buy an original remote to get it unlocked.If universal remote would not work,revert with the model number and i would be able to tel you where to buy the original remote .The last resort would be to open the TV and reset he EEPROM which a technician on the site would be able to perform ( if unable to find original remote from the manufacturer or dealer ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
