Question about Freezers
The fridge is cold but the freezer won't freeze
I have a Miele fridge freezer with 2 motors. the fridge works fine. The freezer motor seems to be working - nice and hot like the fridge one - but the freezer cooling grill remains cold and the freezer is warmer than the fridge!
  • peterjcc Jul 01, 2009
    Thanks. How do I check to see if it's a leak or not?
  • peterjcc Jul 06, 2009
    Thanks alot for your help. I think I'll get a guy in to look at it.
  • 40 Answers
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Posted on Jul 01, 2009
  • quellen1980 Jul 05, 2009
    Basicly you can not do it by yourself you need special equiptment.and a techical person.
    Need to open the circuit from charging side with a pipe cutter.Vacuum the system . then charge with suitable gas with the same amount written in the nameplate.Run the appliance and the best way is to use a leak detector.other way is to make bubles with a shampoo and check the leak but small leakes can not be detected by this method also leaks in the suction side is hard to detect by this.
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
I have a 20 cf upright GE freezer that isn't
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.. freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 | GE Freezers
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Freezers Logo
634 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
