Question about Cuisinart DGB-600 Coffee Maker
My Grind & Brew Thermal carafe has water between the walls and I don't know how to disassemble it to get the water out. I've taken the handle off, but afraid to go any further for fear of ruining it. What do I need to do?
  • 519 Answers
YOU NEED TO PUT YOUR FEARS ASIDE AND TAKE IT APART, AS IT'S USELESS TO YOU AT THE MOMENT ANYWAY
Posted on Jul 01, 2009
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
As coffee brews it spills out everywhere. At first if I made minor adjustments to where the pot positioned under the filter it would help, but it seems to be getting worse. I can't make a pot of coffee...
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a cuisinart Grind and Brew with a glass carafe - not pictured above. The self clean button keeps lighting up and I don't know how to run the clean cycle.
Fill the water reservoir with 2 cups distilled white vinegar and 2 cups water - then press the self-clean button. If the water doesn't start going through after a minute or two, just turn the machine on like you were brewing coffee. After the vinegar/water soultion has gone through the machine, brew one cycle of plain water to flush out the vinegar. If the self-clean light stays on, just unplug the machine for longer than 20 minutes, and the light should not come back on when you replug the machine. Good luck!
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart Grind and Brew, 10 cup, black
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Brand new, first run, leaking?
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a flashlight....you'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
Aug 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Cuisinart DGB-600 Coffee Maker Logo
104 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
