Question about Equator EZ 3710 CEE / W Ventless Washer/Dryer Combination
Equator ez3710 not working
Hello I have a problem with my combo, it has stop drying, it just washes over and over and never stops? Is there anything I can do.
Thank you
  • Stew Gotz Nov 19, 2007
    I THINK I'm having the same problem... the WASHER KNOB has broken off my machine, so it's REALLY hard to tell what mode/cycle it's on... or where to turn it for "DRYER"
Call a repair man or somebody like that and they will fix it....trust me...it happened to me before!!!! :) ♥ your friend wizzz
Posted on Dec 19, 2007
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
I have the error code 5 on the Ariston washer dryer combo AWD 121 what does it mean
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
Jun 07, 2010 | Ariston Technologies AWD121WH
Dishwasher wont work - starts but then stops and the light flashes. Have tried cleaning it out but dont know what else to look for?
Hello, Try this Crack the door open and then hit the following botton combination high temp wash - heated dry - high temp wash - heated dry then close the door and hit the cancel button. wait for the pump to stop. Hope this helps! Mike
Jan 05, 2010 | Whirlpool Dishwashers
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
The washer stopped in the spin dry cycle. It will not do anything now no matter the dial setting.
Hello.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
  • Jun 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Frigidaire combo washer/dryer screws inside come off
    The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
    Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
    Washing Machines Logo
    164 people viewed this question
    Top Equator Washing Machines Experts
    Heartland Ho
    Level 1 Expert
    Dan Webster
    Dan Webster
    Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
