Question about Refrigerators
Problem with everything freezing inside icebox no matter where the control is set.
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 01, 2009
I have amagic chef 4.4 cu ft mini fridge. when I turn it on, no matter what I set dial to it freezes everything inside. How do I fix this ?
Hi.
This is a classic example of a faulty thermostat.
If it has a electronic controll system the temp sensor is defective.
Oct 28, 2015 | Refrigerators
Everything in the icebox and freezer freezes what can i do how can i solve this problem it has side by side doors andfreezer on bottom
Possibly change of season issue. Try lowering tempt settings. If that doesn't work, then the answer depends on age. If newer and has computer control, then you need a technician, who will ultimately guess that you need a new computer control board. (He won't admit he's guessing). If it's an older unit (without digital settings), the answer is easy. You need a new thermostat control. (They can actually be fixed if you know how to take one apart. It's just dirty relay contacts. But warning, they are complicated to reassemble, and not too expensive to simply just replace and be done with it).
Oct 15, 2015 | Maytag Refrigerators
Sanyo Mini Fridge Freezes Everything
For me I think you have a problem in Thermostat switch contact. Or the rotary switch was not in good contact point, better check it and if still the same, proceed to check your thermocouple if functioning.
Jul 22, 2013 | Sanyo 2.4 Cu. Ft. Compact Mid-Size...
First freezer stopped freezing. now icebox is not cooling at all and freezer is warmer than inside of icebox
You have a bad defrost system in this unit. Call or emailus with the brand and model number and we;ll get the correct part out to you right away to get you cooling again! We look forward to working with you and hope to hear from you soon.
Oct 06, 2009 | Refrigerators
Everything in frig is freezing no matter what setting we put it on
It looks like the refrigerator won't stop running not matter what temperature you set the cold control and that is the problem ,its need to be replaced.
May 01, 2009 | Refrigerators
Ice box
you have a leak or the compressor is not starting,you need to pull the frig. out and see if you see any oil on the lines this would mean the freon is leaking out,also put your hand on the comp. and see if you feel it running if not you would need to go to your local appliance part store and get a 3in1 start kit and install it ,it's easy the directions are to the part,hope this helps you-mike
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
