Question about LG LRBN20510WW Bottom Freezer Refrigerator
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
  • 4,070 Answers
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Jul 01, 2009
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
563 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
