Question about Samsung 215TW SyncMaster 21" LCD Monitor
Samsung syncmaster 215tw monitor flickering
Big Tech suggests changing the capacitors on the backlight power supply. Where could I order these parts and what exact parts are needed? Thanks!
The capacitors BigTech referred to are C110 & C111, 820uf-25V Electrolytic, on the power supply board.
With minor soldering skills, you can replace them with Radio Shack in-store capacitors, Stock # 272-1032, 1000uf-50V Radial Lead Electrolytics for $1.59 each. Works great!
Four bucks and little bit of time saves the monitor.
Posted on Jul 08, 2009
  • thegameh0935 Sep 05, 2012
    you think those capacitors need to be replaced even if they don't look bad?? i'm asking because in my power supply there aren't any bulging capacitors. their top is flat. but i still have the problem.
  • Gary Sep 06, 2012
    Electrolytics do not always show any physical damage. If you have the same problem, replace them. You may be pleasantly suprised. And don't worry about the comment fro BM. They are just filter caps and as long as they are rated higher than the originals, you will get the same service life or longer. Mine still runs after all these years. Not rocket science, although, some engineers would like you to think so. :-)
  • Samsung Master
  • 1,684 Answers
Well you can use the parts from Radio Shack but they are not rated correctly for this use and will fail quickly and could damage the power supply when they do. You need to use low ESR, High temp and high ripple current capacitors in switched mode power supplies. Here is a link to a repair guide that shows what to look for and replace on the power supply board and it has a link to the proper parts. I hope this helps, if so please rate my solution.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
BuddyMc
Posted on Jan 12, 2012
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
My Samsung SyncMaster 215tw stays in power saving mode with the blue power button flashing and won't turn on.
I'd verify all the cable connections first.
You could be dealing with two different problems, bad monitor, or a bad videocard/pc.
I'd swap the monitor out to verify that the computer is working as it should first. Once you determine that the PC is in fact fine, my suggestion would be to change the resolution on the PC to a lower setting then normal. Once that is done Plug the Samsung SyncMaster 215tw back into the pc and see if it powers on.
If it does not, i'd check the cables and swap them with something else to make sure thats not the problem. If you have another PC available, i'd test the monitor on that PC to make sure that it is not the issue.
After all that you'll come to the determination on what the problem is. Sadly, if the LCD is bad you'll have to replace it as they are extremely expensive to repair and generally not worth it.
However, i'd verify if it is under warranty or not, you never know! you might be able to get it fixed for free :D
Mar 01, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Samsung SyncMaster 216BW Monitor
Samsung syncmaster 203b problem
This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Apr 04, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW SyncMaster 21" LCD Monitor Logo
2,268 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
