Question about Amana DK55 Dehumidifier
Have Sears Kenmore model 106.955250 dehumidifier. It keeps on ru
I have Sears Kenmore model 106.955250 dehumidifier. It keeps on running no matter where I set the dial.
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
I have a kenmore dehumidifier model # 129-25803. I have no manual and it is collecting water, but not into the tank, but through a hose tucked in behind the tank and it is running everywhere. how do I...
You will need to disconnect the hose and replace it with a screw on cap that came with the unit. With that in place, the water will be diverted into the bucket. If you are missing the cap, you can probably find a replacement at Sears Parts Direct.Be sure you have the correct model number when searching Sears Parts Direct or before calling them.
I hope this helped you. Thanks for choosing FixYa.
Jul 23, 2011 | Kenmore Dehumidifiers
Have a kenmore dehumidifier 42-54501 - I bought it w/o instruction book. Can you tell me where to get instruction book??? Thank You
Since it's a Kenmore ( a Sears house brand) that was made by Whirlpool. You can download the Owner's Manual at Sears Parts Direct or Sears Parts Central.
Hope this helped you, Joe.
Jun 05, 2011 | Kenmore 54501 Dehumidifier
We moved and cannot find the manual. It is brand new and I cannot fighure out how to keep it running without the manual.
Manuals can be downloaded and printed for Kenmore appliances online at Sears Parts Central.
Hope this helped you.
Apr 27, 2011 | Kenmore 54351 Dehumidifier
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
Sep 01, 2017 | Kenmore 54501 Dehumidifier
Kenmore dehumidifier model 5230
the unit has a sealed system leak and needs pro repair call sears or a&e at 800-905-9505 for service
Apr 28, 2008 | Kenmore 5230 Dehumidifier
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Amana DK55 Dehumidifier Logo
277 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
