Question about Poulan Garden
Ran out of gas, refueled and the unit will not start. Also, the tank has started to leak from the cap prior to this problem. Unit is PBB335 Sting Trimmer.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
Restart after refuelling the tank?
what fuel is it as it can be air in a diesel so you have to bleed it. or you have damaged your fuel pump in a gas car in the uk we call that a petrol car .you pump needs fuel to cool it.
Mar 03, 2015 | Cars & Trucks
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
8 hp B&S amf dynamark rider ran it out of gas, since filled w/new gas starts but quits running after 3-5 mins
try and run it with the gas cap loose when you refueled it dirt might have blocked the vent on the cap
Jul 10, 2012 | Briggs & Stratton Briggs Stratton...
SES Light comes on after we refuel vehicle, code is bad gas cap. We replaced the Gas Cap 3 Times. It still comes on after refueling.
this is not just a bad gaas cap code. it is a leak code for the evap system and will need to be tested to find leak. look underneath vehicle and check hoses on the evap canister for cracks or fallen off the canister is next to tank rectangular box. if dont find anything it will need to be "smoke" tested to find the leak
Sep 24, 2011 | 2004 GMC Envoy
Fuel cap sensor 2004 trailblazer ls ex
Make sure you tighten your gas cap when refueling, until it clicks a minimum of 3 - 5 times. If this does not turn off the light, have it cleared at an auto center, & replace the defective fuel cap. They use an intricate system to equalize air pressure in the tank, to allow gas flow, wthout allowing evaporation of the gas. (Green Friendly) & EPA rules. Thew system is pressurized, If cap defective,, it will set the code.
Aug 30, 2011 | 2004 Chevrolet TrailBlazer
Skylark ran out of gas would not start on refueling. Changed fuel filter
Starved fuel pumps fail. it should be changed ! the fix to a fuel pump is drop the gas tank, on top of the fuel tank there is a round cap with bolts, unhook the wiring harness and pull out the fuel pump, it will have a lever attached. parts stores sale different portions of a pump. you should buy the whole component with the lever(float) . BEFORE you buy a fuel pump check the fuses to Fuel Inj,,,,
Jun 17, 2010 | 1990 Buick Skylark
Have 93 bravada with digital dash. gas bar graph reads eratic have to use trip milage to check for time to refuel. is this due to gas cap and should it be an OE cap
you might have to change out the fuel tank sending unit the floats on some of the older vehicles will start to read wrong and having a digital dash they will go out sooner.
Jun 09, 2009 | 2006 Chevrolet Impala
Idle Problem After Refueling
Sounds like the valve in the gas cap has failed, try replacing the gas cap with the correct one listed for your vechicle
May 04, 2009 | 2001 Toyota Celica
Garden Logo
59 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
