Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 51 from 1991 too much resistance to starting attempts
I have a Husqvarna 51 from 1991 that hasn't been run for a couple of years. When I pull the starter cord it will hardly budge. WhenI remove the spark plug the starter cord works fine.Any ideas on what will free it up so it'll start would be appreciated. Richard
  • 376 Answers
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Posted on Jul 01, 2009
How do I troubleshoot loss of mowing power and other issues?
Low compression ( head gasket ) would account for bad restart.
The 'Hitting a brick' sounds like your carburetor Seat is not working properly and gas is getting past the carburetor ( hence the wet Primer) and getting down into the cylinder. That Hitting a Brick feel was "hydro Lock" TOO MUCH GAS IN THE CYLINDER. See if your Oil is way full and smells like gas. This is being seen everywhere since our idiot politicians created ETHANOL gas
May 12, 2014 | Husqvarna Garden
Husqvarna 500 sewing machine won't turn on
yes, it's possible. also could be the on/off switch, or the power cord.
Jan 24, 2014 | Husqvarna Sewing Machines
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
I have a Beko ZA 90 W freezer that the compressor starts for a couple of seconds before the overload protector clicks out, this proceedure repeats every couple of minutes (when protector resets). I have...
Measuring the windings resistance won't tell you if the motor is seized. Measure the current draw when it tries to start. If it has a capacitor start, check the capacitance is good. If it hasn't got a capacitor start, suspect the compressor is seized. You can try cooling it down for 24 hours and seeing if it will run again as the tolerances these days are extremely marginal. However, if it has seized once, it will probably do it again next time it gets too hot.
May 18, 2012 | Refrigerators
Will turn over but wont start cant hear the fuel pump
If it hasn't run in a couple years, I would use a "test light" and check for power at the plug-in for the fuel pump. If ther's no power I would run a wire from the battery straight to the fuel pump itself. If the pump doesn't turn on you will have to replace the pump. If this starts it. If this makes it work you could put a fuse in the wire and hook it under the hood to any wire that has power when you turn on the key.
If you are trying to get it running again after 2 years it might be a good idea to pick up a Haynes manual for the car. They're only about $20 and have a lot of useful help for the DIYer doing average repairs. Hope this helps.
Nov 12, 2011 | 1990 Subaru Legacy
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
Flashing code 52/ stops washing and you have to start load over again
As per the manual
52. (00110100) Diverter Top-up Fault More than 6 attempts have been made to top-up the water level in the bowl. This then signifies the valve has not closed and is diverting to drain, or the top-up was not increasing quickly enough, suggesting the valve has a blockage and is also draining. Primary Source: Diverter valve. Action: Remove the diverter valve and check for blockages as well as checking that the hinge mechanism on the valve hasn’t broken. Remove the hinge from the solenoid and check that the flap is free to move. Secondary Source: Wax solenoid Action: Check the resistance of the wax solenoid. Also look for corrosion (greenish deposit) on the terminals. Resistance range will be between 0.7kω and 2.5kω. Resistance will depend on ambient temperature and when the valve was last actuated. Anything outside of these resistances and the valve should be automatically replaced.
Apr 18, 2010 | Fisher and Paykel IWL12 Top Load Washer
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
423 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
