Question about Sony KV-36FS16 36" TV
Replace color i need to put more color into my big screen tv. how do i do that, or who do i call to have it done.
  • 372 Answers
Hi.
Try pressing menu on the remote then move cursor to picture & adjust the colour.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 11, 2007
Optoma gt700 is all green after replacing color wheel
we mainly retail or distribute color wheel, light tunnel ect sparet parts for projector or TV, so we have experience on that problem you faced.
perhaps you ordered a compatible color wheel,but it is not big trouble. compared with your old wheel, you will find a black tape, just make it as the same position as your old wheel, it will be ok.
Jun 25, 2014 | Optoma Office Equipment & Supplies
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Sony Rear Projection KP-53HS20 distorted multi colored screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Color wheel
Good day, dkimberly428;
Sorry you are having a problem with your SNG TV.
Let me ask you why did you replace the color wheel? Was it making noise, but had pic prior to changing it?
Okay, if that was it, try this: the color wheel ***'y has one cable and "ribbon type" cable, correct? Okay, make sure both cables are secured. Secondly, the "ribbon type cable" was more then likely put in backwards. If I remember correctly the shiny side (end) of ribbon cable should be facing the rear of TV.
Good Luck, big IRISH. PS always double check ALL cables in TV to make sure they are properly seated.
Jul 19, 2008 | Samsung HL-R5677W 56" HDTV
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Sony KV-36FS16 36" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
