Question about Canon I990 InkJet Photo Printer
Canon i990 prints are too "pink"
No matter how much I fiddle with it the i990 prints are too pink.
(the machine has a new print head). I used a Spyder to calibrate my LCD monitor. All to no avail. Any suggestions?
Re: canon i990 prints are too "pink"
I had the same problem and it turned out to be a combination of the actual paper and media type. Brother brand paper just printed way too pink and some Ilford papers did also. I had an image that was desaturated and even when printing as a greyscale came out magenta.
Was three nights of hard work to get sorted. try printing on plain paper with media type set to plain paper. good luck with it though, I know how frustrating it can be!
Posted on Nov 15, 2007
0 characters
3 Points
Put a new color cartridge in yesterday. First pages printed greens instead of blue. Now only prints pink and red. No other color or even black. I ran a test and it comes out ok.
Try cleaning the print head with something like isopropyl. I had a canon that did the same because the machine was fairly old, had a little use that lead to ink drying on the head and blocking the pransmission of the inks to paper. That may be the issue hopefully. Sometimes compatible cartridges cause problems because they are not correctly chipped.
Jun 16, 2015 | Lexmark Z730 InkJet Printer
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Printers & Copiers
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Despite doing all cleaning and maintenance, and using canon inks, print comes out faint in greyscale and pink otherwise thanks
We have an older Canon doing exactly this. We fitted a few print-head (quite expensive) but the problem remained. As other Canon printers work OK we have concluded that something has gone wrong with the interpreter in the printer and it is sending incorrect instructions to the print head. As this is too expensive to replace we now use this printer as our grayscale and pink printer. (i.e. it sits on the shelf - just in case)
Jan 11, 2010 | Canon Printers & Copiers
Canon i990 printhead
Nothing cleans these printheads well, the best is to replace the printhead, QY6-0055-000, around $70.00
Jul 03, 2009 | Canon I990 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Prints with a pink tinge
Have you tried cleaning the print heads using either regular or deep cleaning modes? You should be able to access this through the software options or on the printer itself. You might also manually clean the ink cartriges with a tissue.
Dec 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Please click the below mentioned link to download a word document containing clean print head procedure:
Canon iP4500- Clean Print Head
Thank you
Aug 01, 2008 | Canon I990 InkJet Photo Printer
Colour of print
A New printer is the most cost effective answer here- they are so cheap No repairs are possible You could check out but you will fiddling around with various suggestions -is it worth it?
Jun 16, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon I990 InkJet Photo Printer Logo
272 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
