Question about Dell U0636 Mouse
Mouse single click results in a double click
  • 41 Answers
Click on to start and then go to control pannel and in control pannel check for mouse ,,,click on to it and try to open the page ,,,,,,,and then under the properties u will get the option for click cycle .....check the setting and make the desire setting change their and the things would start working
Posted on Jul 22, 2009
SOURCE: G7 Wireless Mouse keep double clicking
Same Problem, use canned air to clean it. bash the button a few times. seems to help for a while. Dont bash it to hard or you'll break it. love the mouse but this is a crappy issue within 3 months of use. in a clean environment.
Posted on Jun 19, 2008
antiochpc
  • 1314 Answers
SOURCE: Logitech Cordless Mouse clicks too fast!
Try going into control panel, mouse, and set a longer delay for the double click.
Thanks and please take a moment to rate as FixYa. Thank you.
Posted on Jul 23, 2008
  • 341 Answers
SOURCE: Optical Mouse double clicks on single click
Go to control Panel and click the mouse option. You can change it there
Posted on Nov 26, 2008
SOURCE: mouse double clicks when i single click. sometimes doesn't click.
If this is the same problem that the Microsoft IntelliMouse Explorer 3.0 is susceptible to, it can be fixed! It is a hardware issue that is caused by corrosion on the metal contacts inside the buttons. The corrosion prevents electrical signals from passing between a copper plate and terminals above and below it. You can carefully scrape the contact points with a knife to expose the clean copper.
Follow these instructions at your own risk.
To get into the mouse, peel off the pads on the bottom and unscrew the screws, then carefully pry the shell apart. Do I need to say disconnect your mouse from your computer? Attached to the circuit board inside the mouse, you will see a couple of black boxes.
Look closely at one of the boxes and see that there is a cap with ears that clip onto the bottom half. Wedge a blade into one of the seams between the ears and the bottom half and it should pop up a little. The dull side of the blade should be touching the circuit board. Be careful to not bend the ear. Pop the other ear up and the top of the box should come away.
Study the internals of the black box. At rest, the copper plate is held in place by three contact points: at one end by a pivot point; in the middle by the end of a flex-spring; and at the other end by the upper terminal. When the mouse button is clicked, the copper plate is pressed at its center until the spring gives way and the plate pops down to the lower terminal. This is called a "mousedown" event. When it pops back up to the upper terminal, this is known as a "mouseup" event. In quick succession, mousedown + mouseup = click. If the plate or one of the terminals is corroded, the mouse can become confused, and single-clicks get registered as double-clicks.
Warning: the plate is tricky to put back in! To remove the plate, pivot it to one side, away from the terminals. Be careful to maintain control of the plate. It is tiny and springy, so it likes to fly away. Unless you have very small hands, you need to use tweezers to handle the plate.
Check the contact points on the top and bottom of the plate for corrosion. You can use isopropyl alcohol and a toothpick to rub the corrosion away. Be careful to not bend the plate. If the toothpick and alcohol are not enough to expose the copper, scratch gently and evenly with the tip of a knife blade.
Do the same with the upper and lower terminal.
Now is the time for the most frustrating part. Due to its tiny size and being spring-loaded, the plate can be extremely frustrating to reposition. In my experience, it seems that the easiest way to put the plate back in place the terminal end under the top terminal, then position the spring in the middle (there is groove where the spring is supposed to rest), then use tweezers to pull the opposite end against the force of the spring and seat that end in its groove. Meanwhile, I hold a finger against the top of the plate so it does not fly away if the tweezers slip.
When the plate is successfully positioned, press on the middle of the plate to make sure it clicks up and down the way it is supposed to. Clip the cap back on the black box. You may have to turn the mouse upside-down to do this so the white piece does not fall out. Screw the shell back together and stick the pads back on.
Now, if you didn't break anything, you just saved $30.
Posted on Jun 19, 2009
lauren940
  • 206 Answers
SOURCE: my usb wireless mouse is suddenly double clicking
only by getting a new mouse logitech is having some problems with there mice and keyboards so the only way to fix it without replacing it is to try to reset it but if that doesnt work you will need to replace it
hope this helps!
Posted on Jul 15, 2010
Double click on mouse not workin
Does single click work? if so, the problem is the amount of time between the first click and second click, if the delay is too long, the computer will only register it as 2 single clicks.
Double click settings are change in control panel > mouse
Feb 08, 2012 | Toshiba Satellite L355-S7915 Notebook
I am having trouble with my computer mouse. It is not clicking properly to highlight or will double click when I've only single clicked. Any solutions?
Check mouse settings in control panel. There is some options for double click speed and many other options check once . If double click speed is high then system behaves like this. try to change
Jun 30, 2010 | Logitech Wireless Optical Mouse...
Mouse double clicking when I press the button once
recheck your computer for viruses again and reinstall the driver for your mouse it should work
Nov 07, 2009 | Razer RZ01050300 Mouse
Double click on single clicking the left mouse
Try changing the "Double-Click speed.
2. Check for the Folder option.
Good Luck!!!!!!!!!!!!
Oct 20, 2009 | Computers & Internet
The left button fails to function when I double
On Mouse Property, try faster on 'Double click speed'
Oct 18, 2009 | Microsoft Wireless Laser Mouse 5000
The wireless mouse Double clicks on its own
go into the control panel under mouse and make sure your settings are set to single click insted of double click.
Nov 28, 2008 | Logitech Cordless Mouse
Jul 23, 2008 | Logitech Cordless Mouse
Double click problem
in most cases the best thing to do is to change ur mouse, but i would also suggest u try to use a mouse pad, some paints have a problem when using optical mouse
Feb 18, 2008 | Logitech LX7 Cordless Optical Mouse
Dell U0636 Mouse Logo
213 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
