Question about Panasonic CT-32HXC14 32" TV
No picture no sound nothing
It has happened once before but came back on after unplugging from outlet. It was playing and just went off. It's almost like there is no electricity, no light on the power no picture no sound it doesn't even sound like its coming on. Can you please help? It has been wonderful up until now.
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Posted on Jan 04, 2008
SOURCE:
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
Why does my sharp tv 32k-x1000 picture turn offand wont come back on unless i unplug it then replug in outlet
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 32K-X1000 TV
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 15, 2009 | Nintendo Wii Console
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Samsung HCJ552W 55" Rear Projection...
looks like a power supply unit (PSU) issue. You can not do anything about it. I suggest you contact the service center of your supplier.
Feb 11, 2008 | Televison & Video
Nintendo Ds Sound Problem
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device and look for loosen or unplugged cables in the main bottom board. Usually this dont happen though opening and closing the unit whe it was not assembled correctly may cause the wires and conductors to loosen or even worst to get cut by the moving parts. So as you say nothing else was done with the unit between plays that is the only explanation I can guess from it.
The headset plug is in the bottom main board so no cables are required to get the audio there, though as the speakers are in the top, these require some flexible cables and conductors running throught the hinges to the top part.
Hope to this info to be helpful: How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
Good Luck...
Nov 29, 2007 | Nintendo DS Lite Console
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Panasonic CT-32HXC14 32" TV Logo
328 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
