Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Where to clean the food out
I do not know how to clean the food out of my dishwasher. It is a portable one, it was in the house when we bought it I have the use and care guide to it but it says nothing about cleaning it out. the only thing the guide says is that it is a whirlpool model series 920 and I keep getting food particles stuck all over my dishes after every use I dont know what to do.
  • 82 Answers
A dishwasher cleaner may help. It usually is for lime deposits but it still may break the stuff down enough to flush it out. Wal-Mart or an appliance store should have it.
Posted on Jul 01, 2009
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Regular cycle no longer cleans well
Thanks for the clarification (we get a lot of people on here that don't know how to really use a dishwasher).
Sounds to me like the DW may need a through going over.
Confirm the make and model of the DW so I can see how it's built. I am suspect that with all the food particles and film you mention, that the spray heads are clogged in the spray bars, and, check that the drain hose is not kinked, and it's attachment into the garbage disposal is clear. I've had these clog before, limiting the ability of the DW to get rid of the dirty water.
Dec 17, 2009 | Whirlpool 24 in. DU930PWP Built-in...
Doesn't clean dishes
By clean what exactly do you mean...is there a film...or is it food particles...and did it happen at the other address...and was the other address.....far away or did it have a water treatment.system...If it is just a film as in white deposits...it sounds like hard water and you can install a filter for the water before it gets to the DW under the Sink or and entire system for the House "Hey Culligan Man" :-)...otherwise...it doesn't sound like anything else since the DW worked great at the other address.....thanks and let me know....please rate me if this was helpful...thank you ....The Fang
Mar 26, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Mar 03, 2009 | Bosch SHU9915UC Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Beaumark Whisperwash portable dishwasher has pile of macerated food scraps behind screen at bottom rear of machine. Dishes have "grit" stuck to them after cycle complete. Think the built-in...
That screen is held in place by two screws. Remove the screws, pull out the screen, clean it and put it back. You should perform this cleaning periodically to keep your dishwasher running perfectly.
Gina
Jul 11, 2008 | Dishwashers
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
151 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
