Tv goes fuzzy and when turned of on stand by for 5 mins its ok
It goes fuzzy and granny and when you turn it off for 5 mins its ok then arfter about 30mins it bad again maybe somthing to do with over heating can you help thanks
  • 458 Answers
This is called image retention where the screen is not dissapating the last picture information quickly enough. This can be cured either by adjusting the settings on the Y-Sustain board or a software upgrade can fix the problem. Either way I suggest you contact an LG dealer to arrange an engineer to do this.
Posted on Jul 01, 2009
Ps3 freezes and screen goes fuzzy
Try to restore file system on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
Picture is fuzzy for the first few mins after turning on
This may be an issue with your color wheel where it isn't spinning up to speed at first but finally does after the 2 - 10 minutes. Fairly common in DLP TV's.
This could be fixed by a qualified Hitachi Servicer.
Blessings,
A/V Media Tech Guy
Nov 21, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
Jun 01, 2009 | RCA L32HD32D 32 in. LCD HDTV
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
TV turning off
It needs a 27mhz crystal replacing 1h00 on the board in the middle if the led is flashing 5 times. This requires a rework station and is a professional job.
James
Jan 19, 2008 | Philips 32PF9830 32 in. HD-Ready LCD...
Tv turns on get piture then get fuzzy whit line then goes off pleaze help me
i had this same problem, there is a common fault with these models, and the onyl way to fix it is to get a chip replaced in there...cant remmerb the name of this, but it cost me about £30, now the tvs fine
Oct 31, 2007 | Televison & Video
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
