Question about GE Dishwashers
I have a GE GSD550 series dishwasher. We had a
I have a GE GSD550 series dishwasher. We had a power outage this morning. It is now not washing correctly. It is not cycling in the correct order and it appears to try to wash, sanitize, and dry at the same time. Also, it will stop working and emit a high pitched continuous beep
watugot
  • 290 Answers
SOURCE: Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Posted on Nov 16, 2007
  • 131 Answers
SOURCE: GE ZBD6880KOOSS
This is an unusual failure. The humming could be a motor (or valve) that has power but isn't moving. But that doesn't explain the (absence of) lights on the control panel. I suggest you call a professional.
Posted on Mar 31, 2008
SOURCE: Tecnik dishwasher keeps on washing... and washing!
the "programer" has gone
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Posted on Sep 18, 2009
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Dead after power outage
The breaker may have failed electrically while continuing to function mechanically. It may be necessary to replace the breaker, something GE should have been able to tell you without referring vaguely to "an act of nature" which it wasn't.
Feb 26, 2014 | GE Dishwashers
After a power outage my dishwasher has a "Er" code. I downloaded the manual and it says nothing about that specific code. Please help! "Er" code GE Profile Dishwasher GSD4930X66WW
the er means error. you may have a damaged control from the power outage. try to turn the power off to the unit for 30 min then put it back on. see if it resets it.
Jan 10, 2011 | GE Dishwashers
Dishwasher not working after power outage
Occasionally there is an isolated GFCI circuit for the dishwasher. If you can validated with a voltage meter that the unit is actually getting power.
I used to always install an isolated GFCI circuit for each: microwave, dishwasher, refrigerator, and garbage disposal.
So that is what i would check first
Mar 14, 2010 | GE Dishwashers
GE GHDA485N00CS model dishwasher has no power
I have the same problem with my GE dishwasher. The model number is GDS640P-25BA. Any help for this problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Nov 02, 2008 | GE Dishwashers
Ge triton
Power outage was the culprit for me as well. Resetting the breaker fixed it immediately. YAY!!
Nov 17, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton Dishwasher won't stop running
try to reset the circuit braker--remove all power.
Aug 27, 2007 | Dishwashers
Dishwashers Logo
117 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
