Question about Dometic Rooftop RV Air Conditioner
I have a leak and it does not seem to the be the new gasket
I have a leak and it does not seem to the be seal or the weep holes - could it hurt to calk around the new gasket? I have tightened the 4 bolts as well. The only other option is the seam where the roof halves meet under the AC. The leak is at the back edge somehow but there is no water IN the AC unit. This is rain related.
  • 156 Answers
Mine did the same thing as I have it installed on a trailer that didn't have enough support. You can pull the cover, have someone stand inside and gently spray a mist of water around. I gently sprayed water all along the gasket and found it that way.I found that mine leaked at the seams that you are talking about. I just installed a thicker gasket but you can caulk it. Hope this helps and hey, when you're spraying the water, keep it away from any electrical connections as you know the consequences :>)
Posted on Jul 03, 2009
  • Dometic Master
  • 6,674 Answers
They say you should only compress the gasket to approximately 1/2 it's original thickness, and sometimes there are tabs that touch roof to tell you that's far enough. If your sure it's coming in around gasket where it meets roof, try loosening bolts off to allow you to lift upper unit off roof enough to use a caulking gun with a tube of "dicor" self leveling sealant, and run a bead of Dicor around where gasket meets roof , then set unit back down, & tighten until gasket is about 1/2 thickness as new.I always find it better to remove bolts & flip unit on it's side and get good bead down center of where gasket meets roof, then set unit back down, line it up & snug it down.Let it sit for a while to set a bit. Be ready with a rag to catch or wipe any excess that squeezes out from under gasket to the inside, that may end up on floor below, as it's very hard to remove that stuff after the fact.Has worked for me in similar situations.
Posted on Jul 01, 2009
I have antifreeze dripping from my weep hole on my 2004 r1 what other seals do I need to replace besides the mechanical seal?
Weep hole leak usually means water pump is leaking and often due to bad bearings and seal.
Apr 28, 2015 | Cars & Trucks
2001 2500 silverado 6.0 where is the weep hole?
It is the water pump, i would buy a new thermostat also, you can buy a water pump that comes with a new stat and housing, that is the best way i think and that is the way i do them.
These water pumps are big looking but are very easy to replace, i will tell you that when they leak it is very, very hard to see the weep hole, the area you say yours is leaking is the pump so sure, this waterpumps leak at the mating gasket where the pump meets the block or weep hole, any way it is the waterpump.
you will see the new one , how they put the weep hole it flows through the housing to leak out when bad but hard to see.
hope this is helpful.
Aug 03, 2012 | Cars & Trucks
I've got a 08 r6 thats done 3,700 km with a small coolant leak behind the what I think is the water pump housing. Is it a common problem and any ideas on how to fix it? And cost?
Most Yamaha water pumps have a weep hole that drains off any leakage that migrates into the space between the oil seal on the shaft bearing, and the coolant seal at the impellor.
This prevents the fluids contaminating each other.
Sometimes a seal will leak after sitting dormant (winter storage) for months...and they will seal again after a few rides.
Don't be tempted to plug off the weep hole or crankcase contamination can occur.
Not real familiar with your model...but the bigger touring bike (Venture) the seal can be replaced along with case gaskets for around $60 in parts.
Apr 02, 2011 | Yamaha YZF-R6 Motorcycles
I have an oil leak from a drain hole in front of engine.what could be the problem?
If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
Jan 30, 2011 | 1985 Honda GL 1200 Aspencade Gold Wing
Just replaced the water pump due to a leak not on it but behind the pump. I was told the leak was a tatle tale showing i needed a new pump. I still have anti freeze coming out behind it. any ideas?
The pump does have a weep hole in it. If a seal in the pump fails coolant will come out of the weep hole. Looks like you may have a bad water pump seal, but check gaskets, intake manifold and hoses as these can leak in this area as well. So determine where the coolant is coming from before investing in a new waterpump.
Aug 25, 2010 | 1998 Dodge Ram 1500 4WD
2002 Dodge Ram 1500 5.9L V8 leaking coolant out of what looks to be a weep hole from the water pump. Is my water pump bad, or just a seal (gasket)?
If the coolant is coming out of the weep hole on the pump then the pump will need to be replaced to correct the problem. Hope this will help you.
May 23, 2010 | Dodge Ram 1500 Cars & Trucks
Lossing water out of small hole on under side of motor ? Normal or not
Not, sounds like a seal vent for the water pump, shouldn't leak.
Jan 07, 2010 | 2005 Honda CRF 450 R
Water pump is leaking, can i just replace seal on a honda cbr 400 rr 1988 model.
Not really!
The leaking (weep-hole) is purposely put in the water-pump to warn you that the water pump is defective.
You have to replace the water-pump together with new gasket.
1. Drain the coolant into a container by opening the radiator cap, and the drain-plug under it.
2. Remove the water-pump hose and the bolts .
3. Put in place the new water-pump with new gasket.
4. Reverse removal procedure for installation.
5. Start engine and check for leaks.
Nov 17, 2009 | 1988 Honda CBR 400
Water pump leaking from weephole
  1. moz-screenshot.jpgyou may have problem with the number 33 seal this is basicaly the most common problemme with water pump leaking hole09fb78f.gif
Sep 30, 2009 | 2003 Suzuki RM 125
Anti freeze driping out of seep hole from the bottom of case
hello
there are two different seals on the water pump. the oil seal and the mechanical seal. the oil seal helps seal out the oil from the trans case. the mechanical seal helps seal the coolant from going into the trans case, and vise versa.
the weep hole is there to help diagnose if either seal is faulting. so if coolant is leaking from the weep hole. the mechanical seal is faulting or if the oil seal is leaking oil will drip from the weep hole.
hope this is of some help. thank you.
Mar 24, 2009 | 2006 kawasaki KX 450 F
Dometic Rooftop RV Air Conditioner Logo
204 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
