Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
Lens Error My lens wouldn't originally open, now it does but says lens error and I think there is sand in it too, I'm on holiday is there any way I can clean it myself?
  • 126 Answers
Sand is a killer to cameras. If sand becomes lodged in the lens bellows it will jam. I have never after thousands of repairs had any lasting success in trying to repair. When taking a camera around water and sand buy some sandwich bags to place camera into protects against water and sand.
Posted on Jul 02, 2009
On my Nikon Coolpix S4000, when power is turned on, the lens extends fully, opens, retracts fully, and then closes automatically. Lens Error then appears. It does not make noises and has not been used...
I had the same problem with a similar Coolpix model. It's an error on the lens mechanism. Maybe you pressed the lens by accident while they were retracting, or something like that... It's really a delicate mechanism. I think you have to send it for a service... Sorry!
Mar 15, 2014 | Nikon Coolpix S4000 Digital Camera
Lumix wont turn on the battery is good there are no lights coming on and what was happening before this is the lens wouldn't retract when powering off
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Lumix service as you do not have to run around for spares.
Jun 22, 2011 | Cameras
Camera shows lens error....will not open or close
get estimate before you decide. It will be good to have it checked at the service as you do not have to run around for spares.
Apr 06, 2011 | Cameras
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Powershot e1 says lens error, restart camera and won't work
Were you at the beach? If so, it more likely started when a single grain of sand clung to the side of the camera's lens barrel while it was being closed.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 10, 2009 | Canon Powershot E1 10MP Digital Camera...
Canon lens cover won't open
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
Lens error, restart camera . ..
I found this on the Canon Website, don't know if this will help.
Issue: Lens will not move and camera may display an E18 or "Lens" error.
Solution: Possible solutions for an E18 or Lens Error message PowerShot SD600
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays). Good Luck
Mar 25, 2008 | Canon PowerShot SD600 Digital Camera
Zoom error too
if you spill any thing, like a soft drink,tea,coffee,etc. anywhere around the camera, when the lens barrel is open, it will cause it to stick when it is closed. so when it dries, you are stuck. put fresh batteries in, and with a rubber mallet, lightly tap on the face of the lens, when the camera is powering-up. do not hit it hard. after two taps, my camera lens opened up. you can clean the barrel with some wd-40, with a q-tip swab. use very sparingly. and next time, be very careful where you lay-down your camera. you never know......
Jul 08, 2007 | Fuji FinePix A350 Digital Camera
E18
The "E18" error code indicates an error that involves the lens unit or lens cover and it's make sense that the reason for it is sand. Try to clean lens area using air pressure. In case it will not help, you should send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Aug 14, 2006 | Canon PowerShot S300 / IXUS 300 Digital...
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
333 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
