Question about Logitech LX 700 9674180101
How to diassembly mouseto clean a left button
  • 101 Answers
Is quite easy to take a mouse apart, there is usually only one screw on the bottom which you can undo with a phillips screw driver
If you see no screws on the underside of the mouse they might be underneath the little rubber pads on the underside of the mouse.
Once the screw is out the mouse should split into 2 parts, the top half containig the buttons that you wish to clean. All the mouse buttons are normally connected together on one flimsy bit of plastic that can break easily so be really carefull getting the buttons out. On most models of mouse the buttons will just pop out together with a little gentle pressur or wiggling, try and remember exactly what you do as you dissasemble the mouse as this will make re-assembly a lot easier
Would not reccomend this with an optical mouse(the ones with the red light on the underside)
good luck!
Posted on Jul 01, 2009
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
Double clicking, left button
Hello, if the mouse is double clicking randomly means the mouse button or button soldering are broken, maybe you might want to try opening it up and resoldering the mouse button, if it doesn't work you can use an old mouse button that fits the space and solder that one in the mouse that's having problems, reassemble and see if it works, the good news is that most of the time it does.
Mar 30, 2013 | Logitech Trackman Marble FX Trackball
Left mouse key sticks
Please clean your mouse - the button might be obstructed by food, or whatever:) If you need to, you can unsnap the mouse key with a small electronic screwdriver (without braking any buttons) and then push the button back into place after you have wiped the mouse clean, or, if there is no obstruction, you might have a damaged mouse that needs replacing. Be careful to ask the computer salespeople for a non-Ethernet "Logitech(C)-emulation) mouse if you have a Windows PC computer from before 2000-2005. If you have a Mac, you might have to call warranty, or, replace existing mouse if cleaning doesn't solve the problem. But, there might be room for a DYI of you can make time for the mouse to be checked under appropriate lighting and in a clean room environment. More about that at another post.
Jun 27, 2011 | Computers & Internet
Wireless left sticking button.
Dust has accumulated inside this mouse and will be needed to be opened and cleaned
This happens to all devices in time wireless or not
You will be surprised at all the dust inside of it upon openning
Jun 30, 2010 | Logitech Cordless Optical Mouse for...
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
The left click is not consistently working
you should change your mouse cuz only left mouse have this physicall problem due to extra pressure or hard clicks on it.mouse is sensitive device so repair is not better option.just change it.
Dec 06, 2009 | Razer RP01050101R1M1 Pro Click Mobile...
It has become extremely hard to click with the left-mouse button
if your mouse is new then you can ask for a replacement but if its not its sometimes just need cleaning. open the lid of the scroll wheel then take the ball you can see inside if all the wheels inside are clean...if its not just use cotton buds then remove the dirt. hope itll help
Oct 02, 2009 | Saitek GM3200 Mouse
Left mouse button doesn't work
You need to check the mouse settings.
If the mouse settings are ok. Then you need to replace the mouse.
For more information please visit the below mentioned link.
http://www.microsoft.com/windowsxp/using/setup/personalize/mouse.mspx
Aug 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
Mouse has lost its grip! (electrical grip, that is)
ok. i see your having great time using that mouse and you cared that device for several years. Try open your mouse and carefully remove these buttons of your mouse to clean those dirty stuff stacked on those linings( I believe that you haven't done this before, right?). I believe that this will need to clean a bit to give it back on track again.
Feb 23, 2008 | Logitech Cordless Mouse
Logitech LX 700 9674180101 Logo
78 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
