Question about Canon imageRUNNER 1023iF Black and White Copier
My imagerunner 1023iF is displaying error message E805
What do i do?
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    What is the copier Displaying, it is not showing in your question...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Check if the exhaust fan near the fixing unit is working,this error indicate problem on exhaust fan,could be stuck up or dirty
Posted on Jul 02, 2009
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon xerox ir 400 error E805 the problame is machin display open the front door
This problem due to your composite power supply,you can see 3 blue capasitor has burned,change it with 4 amp fuse near that caps
Sep 07, 2011 | Canon imageRUNNER 400S Copier
Error E805
E805 ERROR . cooling fan failure, mostly heater cooling fan ...
Jul 06, 2011 | Canon imageRUNNER 400S Copier
My canon copier IR2016 has functional error E805
there could be a problem with the main fan and or the dc controller could be bad.
May 19, 2010 | Canon imageRUNNER 2000 Copier
I need to change the date on fax confirmation pages to the current date on a Canon ImageRunner 1023iF.
1)Press the Additional Funktion button.
2)Press the arrowkeys untill 6 TIMER SETTINGS is displayed Press the OK KEY
3)Confirm that DATE TIME SETTING is displayed and press then the OK key
4)Change the date and time
Aug 19, 2009 | Canon imageRUNNER 1023iF Black and White...
Adjust volume canon imagerunner 1023iF
Press "Additional Functions" button. <common settings> should be displayed, if not press the "+" or "-" button until common settings is displayed. Press "ok". Press "+" or "-" button until "Audible Tones" is displayed. Press "ok". Walk through this submenu to locate the fax volume. Press "ok". Adjust as needed. Press ok. Press stop to exit settings mode.
Aug 13, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon xerox
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 03, 2009 | Canon imageRUNNER 400S Copier
Error code e805
The fan wiring is faulty (short circuit, open circuit). The heat dischargefan is fautly.
check wiring of heatdischarge fan
The machine is equipped with a single fan for discharge of heat from inside it.
Mar 04, 2009 | Canon imageRUNNER 2000 Copier
Download standby
Check that you have the rom installed properly on the main controller/board. Or else it could be faulty.
Jun 09, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon Error Message
An E805 code has to do with the failure of one of the many fans within the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Oct 14, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 1023iF Black and White Copier Logo
157 people viewed this question
old marine
old marine
