Question about Electronics - Others
Grundig dab radio guadabr08 nearley new why does the scrolling display go off after about 45 seconds? press any control button and it returns only to go off after another 45 seconds, is this a faulty unit? this cycle keeps repeating .
  • 578 Answers
What are you trying to accomplish
Posted on Jul 01, 2009
My Grundig s350 radio powers off as if it is on some sort of timer. I cannot figure out why or how to stop it.
The ON button is also a SLEEP timer. The timer can be set to 90 minutes, 75, and son on. The shortest time period is about 1 minute. Press the ON/SLEEP button several times. After each press read the number displayed. As you push the button again you will cycle through all available timer settings. Choose one that its long enough for you.
However if you press the ON/Sleep button for a few seconds the radio will play continusously until you turn it off.
Just play with the RED button a few times to get an idea how long to press to make the radio play continuously.
Feb 13, 2013 | Grundig S350 AM/FM/SW Radio
I have used my Grundig S350 radio almost daily, for the past 6-7 years. I went on vacation for 10 days. When I returned home, I turned on the power, lights light up, etc., but no sound...no matter how...
Hi
Its microcomputer chip may have hanged. Just make a reset ans see whether it helps you. It must help you, i"m sure. To reset it;
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
Jul 13, 2011 | Grundig S350 AM/FM/SW Radio
How to reset low tire pressure light
Check all of your air pressures that they are the same. This alert will be present if you get new tires or rotate them or if you are losing air.
Do not recalibrate the system until you have determined the cause of the warning.
1. Turn the ignition to ACC or ON and turn the radio off.
2. Press and hold the TUNE DISPL button on the radio for at least 5 seconds until SETTINGS is displayed.
3. Press the SEEK PSCAN up or down arrow to scroll through the main menu.
4. Scroll until TIRE MON appears on the display.
5. Press the 1 PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
6. Press the TUNE DISPL button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until EXIT appears on the display.
8. Press the TUNE DISPL button to exit programming. A Chime will be heard to verify exit.
Jul 12, 2011 | 2005 Chevrolet Impala
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
How to reset low tire pressure monitor, the reset is in radio controls. 1. Turn the ignition to ACC or ON and turn the radio off.
2. Press and hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
3. Press SEE PSCAN up or down arrow to scroll through the main menue.
4. Scroll until the TIRE MON appears on the display.
6. Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until the EXIT appears on the display.
8. Press the TUNE DISP button to exit programming. A chime will be heard to verify exit.
Hope helps (remember to rate this).
Nov 05, 2010 | 2001 Chevrolet Monte Carlo
I just bought a portable radio Grundig G8 Traveler II Digital. I would like to change the temperature display from Farenheit to Celsius. Is it possible? How could I do it? Thank you Frank Lomas
To commute from °F to °C : simply press the button labeled 9/10k for two seconds to change the medium wave station spacing from 10 KHz to 9 KHz.
GoodyGuy
May 19, 2010 | Grundig Audio Players & Recorders
How to turn off the change oil light
4. Scroll until the OIL MON appears on the display.
Enjoy!!!
Jun 17, 2009 | 2005 Chevrolet Monte Carlo
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Grundig car radio
Make sure that the radio and the ignition are both turned off. On the radio, press and hold down the 'AS' button, then turn on the ignition. After about 3 seconds the radio will beep. Release the AS button. enter the code using the buttons 1,2,3, & 4. For example, if the code is 4739 press, button 1: 4 times button 2: 7 times button 3: 3 times button 4: 9 times When you have entered the code, press and hold down the AS button again until it beeps and your radio should now be reset.
Sep 02, 2007 | Radio Communications
Electronics - Others Logo
282 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
