Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
How do I completely remove the WD Sync software so I can use my 500GB WD external hard drive for manual copy-and-paste
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
Posted on Jul 19, 2009
HOW TO BYPASS THE CRAPPY SOFTWARE
1. Install WD Smartware and update it.
2. Run Virtual CD (VCD) Manager at http://www.wdc.com/wdproducts/updates/?family=wdsmartwareutilities
to remove the virtual CD drive.
3. Use Control Panel add/remove programs to uninstall WD Smartware.
4. Everytime When you plug the hard drive in Windows will come up with the look for drivers window hit 'Cancel'
5. Now use it as an ordinary hard drive!
Posted on Nov 23, 2009
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
My computer has 2 drives (C and D). My WD Passport will recognize and backup the C drive, but it won't backup the D drive. It doesn't split the files into pictures/video/etc like it does with the C, and...
Well, you don't have to use WD's software...you can better backup software like Acronis..you can back any files you want, or, the whole computer with installed programs, operating system and all. Are you using WD software, or windows? You can just select the files you want to copy from the drive in Windows, and just copy them to the drive, you don't have to use WD software.
If this post has helped, please vote.
Jun 15, 2010 | Western Digital My Passport Essential...
How can I completely wipe my wd passport hard drive and start over? there are files and weird backups that i just need to get rid of and totally start fresh but they are protected. help!
With the drive connected to your computer, Open up My Computer, located the drive you want to wipe, right click on it and select Format, you can do a quick format. This will remove all data from the drive so be sure you do not want any data that is on it. This will also remove the WD files that came on the drive as well. If you need these files just copy them to your local disk temporally format the drive and then move them back.
Jan 05, 2010 | Western Digital My Book Essential 500GB...
My samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Oct 09, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
I cannot copy files
I used to get this problem until i updated my USB drivers. Or try a different USB port. I only have USB 1.1 and this device is 2.0. They should be inter-compatible but you know how these things are sometimes. Make sure the temp of the drive is reasonable too, I've not had heat problems with this one but i have with other external drives in the past.
Hope something I've said helps.
Oct 28, 2008 | Western Digital 250GB MyBook External USB...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
12,381 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
