Question about RCA RT2620 System
No sound from rt2620 dvd
TV sound and FM ok ,dvd sound through TV ok , but no DVD sound from rt2620...panel left & right stereo lights blinks on/off. Any ideas before i throw it (rt2620) out
Hey, you will need to reset your coaxial, optical,analog setting back to the analog. Mine did the same thing.
Posted on Apr 23, 2008
How do I set up my tv to play from my dvd player?
All you need to connect is as follows:
1. use a stereo - two RCA- connection cord to connect from the DVD- L/R line/audio outputs to be plugged into the TV's line / Aux In connection which is the sound of the left and right channels.
2. Now connect one RCA cord to link the Video out from the DVD to the video IN of the TV.
Now switch on TV , insert your DVD and select the INPUT Connected, be it LIne 1 or LIne2 to see the picture.
Jul 23, 2011 | Sylvania Televison & Video
How do I get the surround sound to work on the telly and not just through dvd
Using your stereo system for audio portions of video programs - such as DVD, VHS tape, etc, - is a great way to upgrade sound quality. Many people are in the same "boat" as you; trying to get the TV audio out of the TV and into the stereo.
You'll need to located an unused left and right audio input of your stereo. These new jacks may be assigned to "Tape" or something else - but for you, it will now be "TV". You'll also have to locate the left and right audio output for the TV. This may be located on the back of a cable TV box, satellite converted, Tivo, etc. if you such a device to receive TV signals. Simply follow the cable from the rear of these devices to the rear or side of the TV and disconnect. Reconnect the loose ends to the unused left and right inputs on the stereo. If you do NOT use one of those devices, you'll need to find left and right audio OUTPUT jacks on the TV itself.
Many older TV's only offered audio and video INPUT jacks, as there was no need to send signals anywhere else since the TV displayed the picture and had an internal audio amplifier and built in speakers for sound. If you TV only has input jacks, there will be no easy way to obtain the audio output signals. While you could pay a technician to get them out for you, you might be better off obtaining some type of tuner or converter to do the job you instead and do it for less cost.
I hope this was heklpful and good luck! Please rate my reply. thanks.
May 15, 2011 | Televison & Video
Can you hook up a DVD player to this TV? It is a DTQ 13V5FC purchased in 2003.
I took a look at the specs for this set, and it has both front- and rear-panel audio and video input jacks. There's a button marked "VIDEO" on the remote that switches to the AV input so you can watch what you have connected. So yes, you can hook up a DVD player, but there are some limitations.
This isn't a stereo TV, so you'll need a Y-adapter (like this one from Radio Shack) to combine the right and left channel sound from the DVD player into a single mono input for the TV. This means you'll lose any stereo effects from the DVD. Also, even though there are two sets of AV input jacks, the TV can only use one at a time. You can't select the front or rear input separately.
Hope this helps. Thanks for using Fixya!
Mar 26, 2011 | Daewoo DTQ-13V1FC TV
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Hook-up tv to stereo
You will require a sound system and TV that is compatible. I would not suggest to start modifying your sound system and TV. There are serious safety issues involved. There will also be the complexity of designing circuits to have proper impedance matching, input selection, and safe electrical isolation between the devices.
When buying new equipment, it is normal that at some time you will hve to keep up with the times.
Jerry G.
May 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
No sound when playing dvd or cd
  1. Check aux cables should be in Left and Right fornt speakers
  2. Check your dvd sound Settings under menu mka sure the downmix is stereo
Hope ths help
Jan 20, 2008 | RCA DRC220N DVD Player
Setting up the TV with our stereo
Sure. On back of DVD player find 'audio out" left and right.
Obtain a twin RCA jack audio cable of sufficient length and put
the two plugs on one end into those audio ports, and plug
the color matching ends into any available" audio in" left/right
ports (except "phono") on your receiver. Done.
For the TV sound use the same kind of twin cable, and obtain
the sound source from audio out left/right on the back of your
cable or satellite provider box and find one additional set
of available "audio in" left/right ports on your receiver. Done.
Turn the receiver dial to correspond to the audio port that
you selected on the back and enjoy it.
If you don't have a separate cable or satellite box chances
are your TV will have audio out left/right ports in the back
or front somewhere and use those to route your TV sound,
but if you do that don't expect the sound quality to be
top notch (depending on the TV circuitry ).
If you have only one unused audio in left right pair available
on your receiver you will need to use an "A/B" audio
switch, and your local electronic store can tell you how to
use it.
You are doing the right thing. The sound should be much
improved by using your receiver. And by the way, when the
sales person in the store suggests that you need gold plated
jacks ignore him and buy the plastic ones. They will work
just fine.
Good luck.
Jan 04, 2008 | Emerson EWL20D6 Television
Can't get sound out of car stereo system
sound cuts out when volume is turned up
Oct 18, 2007 | Sony MV-900SDS Car DVD Player
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
RCA RT2620 System Logo
122 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
