Question about Nokia 6500 Slide Cellular Phone
My on/off button wont work on my nokia 6500 slide. The battery went and now i cant turn it on :/ (it wasnt working before the battery died) Any tips?
I have them same problem at the moment. If you can find someone with the same phone use their phone to charge your battery just a little bit, and then just put the battery back into the phone because the button is broken the phone should just switch on. If you have the phone on contract then it should still be under warranty, when you take the battery off there's a little tab next to the word 'Nokia' if it is white then you will be eligible.
Posted on Jul 23, 2009
How to unfreeze my nokia lumia 900
Mine just done the same thing all you need to do is hold down the off/lock button for at least 15-20 seconds then the screen should turn black which means you can turn t back on again and It should work.
Jul 27, 2012 | Cell Phones
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
Cant swtich it on battery went flat it is taking a charge but the on /off button wont work it was tempremental yesterday but did come on eventually but today I bviously am not pushing the button exactly...
what controls the on and off button is the flex of the phone that is connected to the board of the phone and makes it to display.
The flex is bad that is why the phone can power o. You will need to change the flex for it to be able to power on the phone again.
Have a nice day.
Mar 29, 2010 | Nokia 6500 Slide Cellular Phone
The key pad does not work. no key responds
Just TURN OFF phone and remove battery for 2-3 seconds, then put it in your phone then try.
If it wont work then go to Nokia Care and tell them about the problem.
Nov 26, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500 slide wont turn on via the power button
You'll have to replace the power switch, please take it to a certified nokia center for repairs.
Kind Regards
Nov 08, 2009 | Nokia 6500 Slide Cellular Phone
My on/ off button fell off 6500 slide how do i turn my phone on
This problem is very simple. I see this question continually popping up when the answer is so simple. You pull the battery out of the phone. On the back of the phone their is a sequence of numbers That represent the phone's BDK. (CODE) write down on a piece of paper the last "number" , e.g CODE:055565('8)OK now You connect the phone to its own charger.. the screen will start to turn on (go white). now just before the screen turns on 100% you disconnect the phone from its charger. repeat this method to the amount of times the last number was. In this case we would repeat this method 8 times, because 8 was the last number on the phones code. I hope I have been helpful ;)
Aug 16, 2009 | Nokia 6500 Slide Cellular Phone
Swapping board from 6500 nokia
I am afraid the boards are different for the two models. I don't think this i the answer you were after but at least you won't end up wasting money buying the wrong one.
Mar 26, 2009 | Nokia 6500 Classic Cellular Phone
My nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500 slide keypads sometimes won't work
Mine does the same. A technician has advised me it's a flexi error.Yet if you want, you can do what I usually do lol...Slide your thumb progressively over button 3,then 2, then 1, then 4, then 7, down to *. Do this continuously and it should work after a few tries.
Feb 07, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
652 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
