Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The agitator will not spin
Agitator is stripped and will not spin
  • 5,911 Answers
If you are talking about the upper portion of the agitator (called the "auger") not spinning, you probably need to replace the agititator dogs. The following link epxlains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple and inexpenisve repair. The part number is included in the information I provided. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 01, 2009
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Won't agitat under agitator yellow coupling held by 7/16 bolt should this spin freely or does this mean its stripped
it probably means that it's stripped. it grips the spine and allows movement of the agitator. the transmission shaft may be rotating back and forth, but the agitator doesnt move properly. i would remove the coupling and take a look underneath it to see if it's stripped.
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
Kenmore washer (27yrs old model821728 just spins does not agitate
hi, the clutch and agitator mechanism is damaged. you will need to replace the clutch and, i would advise to purchase a complete agitator kit. this will allow you to rebuild the stripped agitator components.
May 21, 2009 | Kenmore Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
134 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
