Home | Kenmore | Elite 45986 Front Load Washer | Whirlpool duet clo...
Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
Whirlpool duet clogged drain hose
By napadenny71 on Jul 01, 2009
how do I unclogg it???
Sponsored Links
Best Solution
posted on Jul 01, 2009
Very Helpful)
jsrock516
Rank: Guru  Kenmore Expert Washers & Dryers  Expert
Rating: 96%, 6472 votes
It depends on WHICH drain hose you are talking about. If this is the drain hose that sits in the standpipe at the wall, take the line out of the standpipe and use a wet/dry shop vac on the end of the hose to pull a vacuum on the line. This will dislodge anything that is stuck in the line.
If this is the drain line that runs from the wash tub to the inlet side of the drain pump, remove the line from the pump to retrieve anything that may be blocking it. You will need to remove the lower kick panel under the door to access it. The screws are located under the bottom front edge.
Make sure you also check the drain pump reservoir (if you haven't done so already).
If you are still having problems, or have questions, please let me know. I hope this helps you.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
I have an elite calypso washer and it will not let me change the wash cycle from jeans, it also will... (More)
Answer
agitator makes loud noise during wash and rinse cycle. completes cycle and empties well. any... (More)
Answer
How do I change the front door gasket on a Kenmore Elite Front loading washer HE 3t Model # 42926201... (More)
Answer
My washer makes loud noises when turning. Noise is from the back by the pully.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Elite 45986 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14022
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
