Microtek monitor 997m
When I shut down computer the monitor is turned off by the monitor power button. now the button no longer works and if says on the screen "key code." I did move the monitor and wonder if I locked the monitor so how.
I can't even get the function keys on the monitor to work.
  • luwilson Jul 01, 2009
    tried all button combinations and still did not work
  • 3,940 Answers
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Posted on Jul 01, 2009
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Screen keeps turning out
the problem is the power supply of your main board...you can replace the bulging/leak capacitors...to acces the power supply open the back cover of your tv..the power supply board is the pcboard which the mains supply is connected..you can also replace the whole power supply with a new one..resolder the board for its loose connections..
hope this helps good luck..
please rate my help...tnx for using fixya.
May 30, 2010 | Microtek 997M 19" Flat Panel LCD Monitor
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Buttons no longer work--power and OSD menu buttons don't work
I had the same problem. In frustration after trying everything else as I couldn't shut the monitor off, I shut the computer down, unplugged the power to all, and left it until this morning (12 hours). Now it works, so it must reset itself. I am waiting for feedback from their support as well but imagine they will tell me the same, good luck.
Jan 18, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but...
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Jan 04, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
