I have a flat screen TV that has developed a
I have a flat screen TV that has developed a black cloud in the picture. IT SEEMS TO BE GROWING. eli@amigo.net
  • 458 Answers
From your description this could be crystal leakage. The only remedy is to have the screen replaced.
Posted on Jul 01, 2009
Black cloud like fogged on Sharp Aquos 37"tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We have black line running through out tv that seems to be growing. Is there a way to fix it or stop it from growing?
Lines on all source input?
Vertical (usually bad LCD panel, T-CON board, main board).
Horizontal lines (power supply, main board).
Post the pictures of the screen for us?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have to know if it is my video driver card as my onboard video display works with my flatron screen but when i hook the video card to the tv, or another computer monitor it will not work. It goes into...
NCR Web Solution, Website Design Gurgaon,Web Development Gurgaon ... Web development company: Ncr Web Solutions provides services web designing website development maintenance hosting logo design and SEO from India.Ecommerce website design in gurgaon delhi ncr, Website design in gurgaon delhi NCR, Website design in Delhi, Website development in Delhi, Web design in india.Web Site Design Gurgaon, Web Design Company Gurgaon India, Web Development Gurgaon, ecommerce web site design Gurgaon, ecommerce web development Gurgaon,
www.ncrwebsolutions.in/
Jay Vaishnav Web Designer In Gurgaon
Contact No : - 09999854933
Dec 25, 2010 | Abit IP-95 Motherboard
The TV has a Black cloud on the right half of the
My parents have the same issue with their Sony KDL-46V4100 TV and were told by the tech that the LCD screen was physically broken and would have to be replaced. The replacement of the screen would cost more than a brand new TV and the TV is not longer under warranty. After the TV is on for awhile the Black cloud goes away but it always comes back when they turn the TV off/on. It stays for 20 - 30 minutes sometimes. The Tech took both top corners of the TV and pushed one back and pulled one forward to show them he could recreate the problem after the black blob cleared up. By twisting the corners he made the blob reapper which he claimed was becuase of the damaged screen. I have no idea how the screen was damaged? I helped them take it out fo the box and set it up. We never dropped it bumped it once? It's never falled off the stand so go figure? It would be nice to find more people with this issue and get a recall going. Something that expensive should last longer than to two years.
Jul 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Grey cloud
This sounds like a diffuser problem. Basically the LCD Panel is defective.
32" LCD TV use about 8 horizontally mounted flourescent bulbs. They use a plastic material that diffuses (spreads) the light from each bulb evenly on the screen. If this Diffusion Material becomes wrinkled it will leave a grey cloudy look on the screen.
It is possible that the LCD Panel Glass is defective buy honestly I would guess the diffuser.
This isn't cheaply repairable and it is better to replace the TV unless you are experinced with Electronics repair. There may be a possibility to pull this material out and replace it with something readily available from Home Depot but I have not tried this before. It is possible to pull this from another LCD TV.
Jun 24, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
KV-34HS420-Sony Tv
well based on ur info, ur tv has a prolem in power supply section, particularly regulation circuit. the regulator of the circuit seems to be mulfunctioning thats why insufficient voltage is coming out from B+ which in turn goes to high voltage circuits thats why the produced picture is insufficient. if this is very technical to u, have it check with a qualified technician.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
