Marking on bottom is drawing of elephant head with words Thailand, Siam, pewter inside the circle. Flask was purchased in 1970s in Thailand. Found with alcohol in it. Could be corroded inside? High lead content?
Pewter is usually 95% tin and used for eating utensils for thousands of years. The alcohol should prevent corrosion since it would imped air from getting to the interior. It is very unlikely you will get lead poisoning from drinking it. It is far more likely you will get sick from the alcohol being improperly stored for 40+ years and has gone bad. By the way, alcohol will do that.
SOURCE: i had a transcend 8GB
The WRITE PROTECTION is ON. Please push the little white button on the side to the other end. Then try access it on your computer. If it still gives the same error, push the button to the other end and try again.
SOURCE: damanged flask drive
Sir,
Click this link for more information
http://www.ontrackdatarecovery.com/flash-media-data-recovery/
Thanks
Good Luck
Don't forget to rate tje solution
SOURCE: i have a sony camcorder
You need to install flash player, you can get it from http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash
SOURCE: would like to use my jump drive on my compaq
is it finding the flash drive? have you tried to plug the flash drive into another computer?
SOURCE: how to remove the write
Usually usb sticks don't have a write protect option. But some models that do have that option. Look for a small switch on your usb stick.
Hope this helps!
A thermos is a vacuum flask that has two flasks. One flask is in the other flask and they are joined at the top. The gap doesnt have a lot of air. This makes a near-vacuum with the prurpose of stopping the transfer of heat or cold. Therefore, the thermos keeps a drink hot or cold.
