Question about Refrigerators
My kenmore side by side was pluged into the wall with a cord and my son hit the cord and the Compressor stoped coming on. The light and the ice maker work. Can I fix this my self?
  • 4,070 Answers
If you hear a clicking at the compressor when you try to turn it on, replace the starter relay.
Posted on Jul 02, 2009
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Our Kemore fridge stoped making ice. water is coming.. It has infra red light control for ice maker to stop when bucket full of ice.
Open up the door ,hold in the bracket that is on the side(usually lrft side) and if the sensor light keeps blinking,it has to be replaced.HOpe this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a Whirlpool Mark Series refrigerator and the ice maker is squeeling. I'd like to just turn it off or disconnect it but don't know how...
on the left side there is a pig tail( the power cord ) it pluges in the side of the head / just relace it and it will come out and ice maker is disc .. mm
Aug 17, 2010 | Whirlpool GD2SHGX Refrigerator
Ice maker just stopped--red light near on/off switch is flashing
unplug the unit for 5 minutes and plug in again and see if it clears the memory and resets
Aug 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hgkl
Jun 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
On my 106.55244400 refrigerator, does the cord to
If you remove the 3 screws holding the ice maker to the wall , and you do not see a plug at the rear , then unplug the refrig . Remove the ice maker cover ( it just snaps off ) . Where the line connects to on the ice maker , you will see a small square hole with a " flap " which has to be depressed , and the wiring will slide out , after unclipping the black fuse piece , from the mold .
Nov 13, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
heatman101
jfjfk
Jul 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator stopped.
There is no fuse in this refrigerator other than a fusable link located in the ice maker harness at the ice maker itself. There is an automatic reset breaker overload assm located on the side of the compressor that controls only the voltage to the compressor itself. Give specific details about your problem. Do lights come on, fan or fans run? supertechks
PS:find the model # on the identification plate, it will start 106.########
Nov 21, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
