When you open any web site so open web site minis Internet is working fine so go to the control panel and open add /remove program and remove the yahoo msg and downlod new yahoo msg from yahoo website and install after login user I'd and password then working ...ok Any problem fell free contact
You should really be using firefox. In IE go to tools, internet options, security and restricted sites. If you see Yahoo there remove it. Also go to trusted sites and allow yahoo.ca and yahoo,.com. That should fix your problem.
Re-booted the system several times before it would clearly shut down properly. Then went onto several different e-mail sites which showed no problems getting the e-mail. I still have no idea what really fixed this problem but the next day, everything was working fine. Thanks.
Have not found solution--can only log onto your responses every few hours--otherwise can not log on.
Yahoo says no problems--computer tech says no problems--well there is somewhere!!!!
Can acsess all other sites but yahoo.Have had to transfer contacts to other sites as can not afford to miss important contacts.But thanks for trying.Have no intention of paying for services twice.
somehow the yahoo site is blocked..Ok try this In the drive you have installed ur OS search for the file named "hosts".When you find it open it with notepad and in that search for yahoo.com..If it is there in the list..then just remove it..It will be something like.. 127.0.01 www.yahoo.com..And then just save(dont select save as because it will be saved as a text file) and that should do the trick.. Let me know what happened before you rate..
