Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Want to turn off all the led lights with one buttton
    Problem Solver:
  • 15 Answers
Not possible to program, but you can press and hold the MAIN button for 10 seconds to set the lighting paramters of your MX-3000. For more information please contact www.totalcontrolremotes.com / info@totalcontrolremotes.com for all issues regarding the MX-3000 and programming this remote.
Posted on Sep 06, 2009
  • 23 Answers
Press and hold down the "MAIN" button for 10 seconds or until a menu screen comes up. Here you will find your basic preferences for your handheld - lights, tilt, brightness, calibration, etc.
Total Control Remotes
Advanced Control & Programming
Posted on Jul 13, 2009
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
My tv will not turn on
Does it have a LED on the front panel when you connect it to power?
If yes does it change when you press the power buttton?
if not then you most likely need power board PK101V0560I - it can be found for about $40 on ebay.
No guarantee, but it's the most likely case and cheap enough to try instead of spending time learning how to test it.
Hope this helps. If the guess turns right you may consider sendign us your old defective board instead of trashing it. We'll pay you the shipping of $10 once we receive it. Email for details if interested.
www.coppelltvrepair.com
Jun 05, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
I accidentally drop my gerber firecracker flashlight, when I turn it on its not working any more.How can I detach the crown from bulb to fix the problem.Thanks for the help.
Hi I had the same problem. It seems that when I dropped it the back buttton got stucked, so what I did was to unscrew the back part (as if to replace the battery) and gave it kind of gave it a knock or hit it softly just to jiggle the button. Scre it back on and got it to work, Hope it works for you.
Jan 18, 2011 | Gerber Blades Gerber Firecracker LED...
Cant get controllers to connect to the x-box
Under the second memory stick port is a little buttton, when you press that button the green led of the xbox should be spinning. When it is press the same button located on the top of the controller of the Xbox until it starts spinning. At that point they should both pair up.
Rylan
Dec 28, 2010 | Microsoft Xbox 360 Console
I have a JVM-1650-ch01 space saver oven hood and the oven light will not turn on. I've replaced the bulbs and the read out says that the light is on but the loght will not turn on by pressing the...
Sorry to read about your problem, I hope this helps you out.
The main control board controls the lite with a relay,, the relay is defective or you may have a broken wire
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How start lighting pilot
turn switch at gas valve 2 hold buttton down 3 with button held down light pilot or push spark button 3 times and continue to hold button down for aleast 1 minute then let off button turn to on position
Sep 29, 2010 | Heating & Cooling
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Ps3 problem
turn the system off completely and then back on with the main power switch on the back off the console. If that doesnt work call Sony technical support for further help.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Faxing issues
What button do see on the printer :::
Can you see a FAX button : press it led should glow on the fax buttton .and let me know ....
Mar 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
65 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
