Question about Movincool Classic Plus 26 Air Conditioner
My air conditioner is leaking water - Movincool Classic Plus 26 Air Conditioner
    Scholar:
  • 86 Answers
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Posted on Jul 02, 2009
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
22yooper
  • 828 Answers
SOURCE: rv air conditioner leaking
In each of these cases I would check for proper connection of the return air vent to the A/C from below. Static pressure from insufficient return air could cause negative pressure to hold back on condensate drainage. when the unit is shut off the pressure becomes equal allowing water to drain. Also check air filter and clean if found necessary.
Posted on Jul 18, 2008
  • 31 Answers
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Posted on Nov 17, 2008
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
Should my 10,000 btu window air conditioner be leaking water all over my balcony
Air conditioners put out cold air, exhaust hot air, and produce condensation when they are in use. The condensation is the water that is dripping out of your air conditioner.
Your air conditioner is not broken, but it would be wise to determine a way to direct the water off of the balcony.
May 22, 2011 | Whirlpool Heating & Cooling
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
My AC unit leaks an inordinate amount of water into the apartment. Most of the times it happens when the humidity is high. I have to put rags inder the unit to absorb the water & change the rag after...
Check your air filter, the unit may be freezing up because of not getting enough air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
Leaking water at the bottom of tank
sounds like u need to add a p trap to stop the air sucked through the drain {pulling the water back}
Apr 14, 2010 | Mastercool 67680 Evaporative Cooler Air...
Leaking
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Jan 10, 2010 | DeLonghi PAC C100 Air Conditioner
Air conditioner is leaking but lights not blinking
Jun 15, 2007 | Sharp CV-P09FX Air Conditioner
Movincool Classic Plus 26 Air Conditioner Logo
140 people viewed this question
Top Movincool Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
