Question about Garden
Drive belt install on JD GT275
When installing a drive belt (the one from the motor to the transmission) on a JD GT275 there is a metal bracket with loops on both sides of the motor pulley. I don't know if the belt is to go between the loops or on the inside of the loops. Do I have to take the bracket loose to run the belt on the inside of the loops or does the belt just run along side the bracket?
  • 68 Answers
The bracket with loops keeps the belt in position when it is slack (disengaged). The bracket usually has to be loosened to even get the new belt on, the belt ONLY runs on the pulleys.
Posted on Jul 04, 2009
How do I install fan and alternator belt?
question 3 , and double posted....
and still no hint as the the JOB.
what are you doing and why, so we are on same page?
wow,,, you do make this so hard.
if the questions is new belt time"only"?(yes? do i guess good?)
then i posted last post all 11 steps from the real fsm ON REMOVAL. so, now I add page 2.
So now you want ,INSTALL too?
the below only works if you did page 1 correctly
ok here. 11 more steps, totaling 22
Install the drive belt to the crankshaft pulley, the tensioner and the generator.
Rotate the drive belt tensioner clockwise.
Install the drive belt to the idler pulley (1).
NOTE
Important: Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
Slowly release the drive belt tensioner.
Raise the vehicle.
Install the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Install the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Lower the vehicle.
Install the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Remove the engine support fixture. Refer to Engine Support Fixture .
Install the the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Jan 08, 2016 | 2005 Suzuki XL-7
How to replace drive belt on john deere riding mower gt275
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
John Deere GT275 Riding Mower Service Repair Manual
Oct 07, 2015 | John Deere Garden
How to install the alternator belt in a 2008 Suzuki xl-7?
which engine option, you do know belts are not same on all engines right? fact.
2.7L V6 or bigger? IDN.
same on all cars. (answering in generic form do to above)
loosen the tension-er.
take off old
put back new
and if not a spring tension-er,set proper tension
the fSM cover all this.
why not read the manual, RTM?
here is one example (get the book, RTM or see alldata.com)
2008 xl7 engine
Removal Procedure
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Install the engine support fixture. Refer to Engine Support Fixture .
Remove the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Lower the vehicle
Rotate the drive belt tensioner clockwise to release the drive belt tension.
Slide the drive belt off of the belt idler pulley (1).
Remove the drive belt from the accessory drive pulleys.
end remove
beg, install
NOTE
Raise the vehicle.
Lower the vehicle.
end.
Sep 07, 2014 | 2008 Suzuki XL7
Nordictrack 1750 Drive roller installation problem
In order to remove that roller you need to do two things. 1. Take the drive belt off the roller and motor pulley. Just press it to the side while you move the motor, it will start to walk off. 2. Loosen the rear adjustment bolts with an Allen wrench. Loosen both bolts till they are almost out of the roller. Once the belt is loose you can take the front roller out.
Jul 27, 2017 | Exercise & Fitness
A2550 motor belt still slipping after replacing it with a new one. and there is no ajustment on the dirve motor, what to do?
Harvey, there are problems with the front plastic pully slipping on the metal drive roller. It appears that the drive belt is slipping. Just make sure that you rule the pully out first. If after that the pully stops with the front roller and the walk belt, there are only Two different drive belts used, double check the part number. Usually I use a ratcheting strap to pull the drive motor up to the bracket, because the belt is so tight there is no other way to get the motor close enough to the bracket to get the 3/8" bolts to even start into the motor. If you did not severly struggle to install the new drive belt, chances are its the wrong one.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Oct 18, 2011 | Nordic Track NordicTrack A2550 PRO...
How do i replace an alt on an 97 Grand Voyager?
When you says ALT, I'm assuming that you are talking about ALTERNATOR...
REMOVAL & INSTALLATION
2.4L Engine
  1. Disconnect the negative battery cable.
  2. Remove the accessory drive belt.
  3. Unplug the push-in field wire connector from behind the alternator.
  4. Remove the B+ nut and wire from behind the alternator.
  5. Remove the nut securing the top of the alternator to the adjuster bolt (a.k.a T-bolt).
  6. Remove the alternator pivot nut and bolt, located below the alternator.
  7. Remove the alternator from the vehicle.
To install:
  1. Install the alternator into position on the vehicle's engine.
  2. Install, but do not tighten, the alternator pivot nut and bolt.
  3. Install the nut securing the top of the alternator to the adjuster bolt.
  4. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  5. Plug in the push-in field wire connector onto the back of the alternator.
  6. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys, especially the alternator.
  7. Adjust the drive belt and tighten the adjuster/locking bolt to 40 ft. lbs. (54 Nm).
  8. Tighten the pivot bolt to 40 ft. lbs. (54 Nm).
  9. Reconnect the negative battery cable.
  10. Verify the charging rate of the alternator.
3.0L Engine
  2. Remove the windshield wiper/motor module assembly.
  1. Remove the accessory drive belt from the alternator.
  2. Remove the bolt securing the top of the alternator to the mounting bracket.
  3. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  1. While holding the alternator, unplug the push-in field wire connector from behind the alternator.
  2. While holding the alternator, remove the B+ nut and wire from behind the alternator.
  3. Remove the alternator from the vehicle.
To install:
  1. Hold the alternator in position near the mounting bracket, then connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  2. Plug in the push-in field wire connector onto the back of the alternator.
  3. Place the alternator into position on the mounting bracket, then install the bolt securing the bottom of the alternator to the lower pivot bracket.
  4. Install the bolt securing the top of the alternator to the mounting bracket. Tighten the upper and lower alternator bolts to 40 ft. lbs. (54 Nm).
  5. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  6. Install the windshield wiper/motor module assembly.
  7. Reconnect the negative battery cable.
  8. Verify the charging rate of the alternator.
3.3L and 3.8L Engines
  3. Remove the accessory drive belt.
  4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
  1. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
  3. Remove the alternator mounting bracket from the vehicle.
  4. Rotate the alternator toward the dash panel.
  5. Unplug the push-in field wire connector from behind the alternator.
  6. Remove the B+ nut and wire from behind the alternator.
  1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  2. Remove the alternator from the vehicle.
To install:
  2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
  3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  4. Plug in the push-in field wire connector onto the back of the alternator.
  5. Rotate the alternator forward away from the dash panel.
  6. Install the alternator mounting bracket in position on the vehicle.
  7. Install the bolt to secure the top of the alternator to the mounting bracket.
  8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
  9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
  10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
  11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  12. Install the windshield wiper/motor module assembly.
  13. Reconnect the negative battery cable.
  14. Verify the charging rate of the alternator.
Hope helps woth this, remember rated this help. Good luck.
Jul 08, 2010 | 1997 Plymouth Grand Voyager
Need a diagram of the adjustment or tension bolts for installation of alternator on 1995 Ford Aerostar-4L, Front 2 wheel Drive
This is from the workshop manual, direct quote.
Generator, Aerostar
Removal
1. Disconnect battery ground cable (14301).
2. Remove snow/ice shield.
3. Remove engine air cleaner intake tube (9A624).
4. Disconnect generator wiring at the voltage regulator (VR) (10316).
5. Remove attaching nut and wire from generator (GEN) (10346) output terminal.
6. Remove wiring connector bracket.
7. Loosen the drive belt tensioner (6B209) and remove the drive belt (8620).
8. Remove generator brace (10B315) and bolt attaching generator to drive belt tensioner bracket.
9. Remove generator from the generator mounting bracket (10153).
Installation
1. Position generator on the generator mounting bracket.
2. Install the attaching bolts and tighten to 40-54 Nm (30-40 lb-ft).
3. Install the drive belt over generator pulley (10344).
4. Adjust the drive belt tensioner as outlined in Section 03-05.
5. Install wiring terminal and attaching nut on generator output terminal.
6. Install wiring connector bracket.
7. Install engine air cleaner intake tube.
8. Install snow/ice shield.
Nov 05, 2009 | 1995 Ford Aerostar
Replace alternator
This is for both size engines since you didn't list the motor size......
REMOVAL & INSTALLATION 2.0L Engine
  2. Remove air intake resonators.
  3. Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
  4. Unplug the connectors and remove the cables from the alternator.
  5. Raise and support the vehicle.
  6. Release the drive belt tensioner and remove the drive belt from around the alternator. NOTE: It is not necessary to remove the drive belt from the engine.
  7. Remove the alternator mounting bracket bolts and remove the mounting bracket.
  8. Lower the vehicle.
  9. Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle. To install:
  11. Place the alternator into position and install the mounting bolts finger tight.
  12. Install the power steering hose bracket and tighten the retaining nut and bolt to 70–106 inch lbs. (8–12 Nm).
  13. Raise and support the vehicle.
  14. Install the alternator mounting bracket and retaining bolts and tighten to 15–22 ft. lbs. (20–30 Nm).
  15. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
  16. Lower the vehicle.
  17. Tighten the alternator mounting bolts to 15–22 ft. lbs. (20–30 Nm).
  18. Install the alternator connectors and the cables. Tighten the terminal nut to 80–97 inch lbs. (9–11 Nm).
  19. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
  20. Connect the negative battery cable.
Apr 01, 2009 | 1999 Mercury Mystique
Garden Logo
1,102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
