Question about Coleman Powermate Premium Plus 6250W Portable Generator
Powermate 5500 no Power on plugs, shorted stator symptoms?
We have a heavy use 5500 which no longer puts out any power to the plugs (240 or 115s). We have gone over everything (brushes etc) to no avail. When we put a DVM to it we found that all the power plugs (+/-) and gnd are shorted. This does not sound right, is this a symptom of a burned out stator?
TIA.
Raph
  • altitude909 Jul 30, 2009
    Thanks for the comment. I did solve it btw, as it turns out, the connecting wire to the rings on the rotor broke in the silicone reinforcement (it was the inside one so it was hard to see). There was inf resistance (open circuit) when I took the reading with a DVM where it should have been ~3.5 Ohm. I simply soldered in a thick gauge bus wire to make up the length since the wire in the broken state would not reach the terminal and i am back up and running!
  • 57 Answers
Stator resistances should be around .5 ohms. This may look like a short to you. Unhook the regulator from the field brushes and put 12 volts on the field winding. you should get output to partially light a bulb..maybe 60 volts. Remember to use 12 volts dc on the fields and don't reverse the polarity.
If there is output then the avr(voltage regulator) is probably bad. If there is no voltage then check the resistance on the brush contacts. through the bushes and field. Maybe around 25 ohms. Your generator manual can give the exact ranges. No resistance then clean the brushes and slip rings and check again. No resistance...take reading on the slip rings. No resistance...open field...bad rotor. Good luck....keep posting until problem is resolved.
Posted on Jul 30, 2009
The 220 outlet is only putting out power on one side
What brand of generator and KW? If you onlyone leg of the 22V it us not likely to be the voltage regulator aor rotor. Check to make sure that the voltage is checked right off the stator leads, where they feed the circuit breaker, and not on the load side of the circuit breaker, If you only have 120V on one of the 240V lines at that point, it is the stator winding. Renee advancd-power-technologies.com
Nov 02, 2013 | Coleman Powermate Powermate 5000W...
Stator got hot on my generator
Stators can get hot, but not too hot? how much are you talking. This is indicative of a short in the output wires, and / or overloading with inductive loads. Compressors, motors, fans etc
Apr 10, 2013 | Coleman Powermate Powermate 5000W...
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Nov 05, 2012 | Coleman Powermate Powermate 5000W...
No output coleman powermate pm401211
Check the capacitor first,check rotor diodes, rotor and stator for shorts, and brushes
Oct 27, 2011 | Coleman Powermate Powermate 5000W...
I have a PMC543250 Powermate generator. It just
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Feb 16, 2010 | Coleman Powermate Powermate 5000W...
No output
you need to replace your breaker frist. than check your rotor ohm and than your stator for shorts. you may want to check the cover were the bearing is there is a metal ring that may have came out and hits your brush cover. look for black burnt marks
Oct 13, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 5500 watt output unbalanced
Get on their website and get the wiring diagrams. They should also have the resistances of the windings. Checking these resistances, may indicate a stator problem. Give the model number and it will be easier to help.
Jul 29, 2009 | Coleman Powermate Powermate 5000W...
I have a Honda generator model Eg1500c. It seems ok....120v 60Hz..but occasionally the motor acts as if it is under a very heavy load and the voltage goes up to 200+ volts. The brushes look good and the...
It sounds like there may be an intermittent short in the output or the stator windings. You'll need to carefully check for bad insulation between the winding and ground, I'd use a megger for this.
regards,
Carl
Feb 20, 2009 | Coleman Powermate Premium Plus 6250W...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,127 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
